[Mapbender-dev] Mapbender 2.5.1 rc1
Christoph Baudson
christoph.baudson at wheregroup.com
Wed Feb 11 09:23:42 EST 2009
I forgot to add the following two lines (see below)...this has changed:
By this, we do not have to touch the dump for minor releases. This will
save a lot of time and will enhance stability. I added this info to the
install.txt file. I also renamed the SQL files (I added the version number).
You devs might want to check out the database setup shell script I made
to test the dumps. It's located at
resources/db/install.sh
The mail to the user list is complete, here are the missing lines:
IMPORTANT: Even if you install Mapbender from scratch, you need to
execute the update SQL for Mapbender 2.5.1, as it is only a minor release.
WICHTIG: Selbst wenn Mapbender 2.5.1 rc1 neu installiert wird, muss das
Update SQL für Mapbender 2.5.1 rc1 ausgeführt werden, da es sich nur um
einen "minor" Release handelt.
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
