[Mapbender-dev] New module mapdiv (Mapbender without iframes)
Christoph Baudson
christoph.baudson at wheregroup.com
Mon Jan 5 04:59:27 EST 2009
The work on the mapDiv had been continued on Jan 2nd 2009. The changes
have been merged into trunk and will be part of Mapbender 2.6. By
default, the map frame will now be a div and no longer an iframe,
however the old iframe element will still be functional.
I had to make some minor changes today to the map object. Apparently we
must not store the actual DOM element. When exporting the map object to
JSON (we need this for save WMC), this ends up in an infinite recursion.
Take a look at the changeset to see what I had to tweak to make it work
http://trac.osgeo.org/mapbender/changeset/3400
We will fix possible bugs regarding these changes in the following weeks
as they arise.
Christoph Baudson schrieb:
> At the recent development sprint nimix and I worked on an improved map
> module. The difference is, that it will be a div, and no longer an
> iframe.
> There are still some modules we need to adjust in order to work with
> new map module. One challenge is, for example, the change from
> absolute positioning (within a frame) to a relative positioning
> (relative to the div). Nimix and I consider this to be another day or
> two.
> If you have any questions on this module or the implied changes,
> please reply on-list.
> In my opinion we should replace the existing map module mapframe1 by
> this new module. I will add a motion about this in the near future, so
> please make sure you are well informed if you plan to vote on the motion.
> More info on the development sprint can be found here
> http://www.mapbender.org/Mapbender_Development_Sprint
> Thanks,
> Christoph
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
