[Mapbender-dev] Trunk
Christoph Baudson christoph.baudson at wheregroup.com
Mon Jan 5 05:50:26 EST 2009
In case you want to install Mapbender from trunk, please
* use the SQLs from 2.5
* update your database with "update_2.6.sql"
I removed the schema and data SQLs from trunk, because they are not up
to date. We should only add them to branches after a release has been
made. The dumps should remain unaltered. Bugs can be fixed by update
SQLs. By this, we always keep the update SQLs up to date.
 FOSSGIS Konferenz 2009
 17.-19. März 2009 in Hannover
 http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
