[Mapbender-dev] update of mapFiler.php available
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Tue Jan 13 12:28:40 EST 2009
Hello again,
just a little correction
the mapFiler is available at the link
http://trac.osgeo.org/mapbender/browser/trunk/mapbender/tools/mapFiler.php
(the folder tools moved out of http-directory for security reasons)
If you want to read more about "Why shall I use _4.map files?" have a
look at
http://www.mapbender.org/Print
http://www.mapbender.org/Troubleshooting_printPDF
best regards
astrid
Astrid Emde (WhereGroup) schrieb:
> Hello,
> for high quality print in Mapbender we generate separate mapfiles (UMN
> MapServer) for the print to ensure that the symbols and textes will
> have the same size and are not tiny.
> To write the mapfiles Uli wrote a tool named mapFiler I did some
> changes on the mapFiler to handle UMN MapServer 5.x mapfiles.
> If you want to try the mapFiler it is available at
> http://trac.osgeo.org/mapbender/browser/trunk/mapbender/http/tools/mapFiler.php
> In future Mapbender Version you will also find the tool in the tools
> directory .
> The new version is not tested yet. If you have any feedback or change
> requests let me know.
More information about the Mapbender_dev
