Fwd: Re: [Mapbender-dev] Re: Catalog Schema and Storing Op values
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Fri Jul 10 03:34:13 EDT 2009
not only to mifam - sorry i forgot the list
---------- Weitergeleitete Nachricht ----------
Betreff: Re: [Mapbender-dev] Re: Catalog Schema and Storing Op values
Datum: Freitag 10 Juli 2009
Von: Armin Retterath <armin.retterath at lvermgeo.rlp.de>
An: mifan at opensource.lk
good morning mifan,
the schema i described in part 7 was only a hint ;-). i know that there is a
problem when there are the two bindings http and soap. there are many urls to
handle with. maybe we can split the soap binding from the http and create a
new table 'cat_op_soap' for it? maybe the schema would be something like :
fkey_cat_id, cat_op_getcapabilities, ...
please think about it and check it for usability - in future we have to
integrate the soap binding for wms and wfs in a similar manner.
the second table will make the updates a little bit more complicated - but
this is a problem of the standards and we must handle it on an easy way.
an other possibility is to store the whole xml part:
<ows:Operation name="GetCapabilities">
<ows:DCP>
<ows:HTTP>
<ows:Get xlink:href="http://www.portalu.de:80/csw202"/>
<ows:Post xlink:href="http://www.portalu.de:80/csw202">
<ows:Constraint name="PostEncoding">
<ows:Value>SOAP</ows:Value>
</ows:Constraint>
</ows:Post>
<ows:Value>XML</ows:Value>
</ows:Constraint>
</ows:Post>
</ows:HTTP>
</ows:DCP>
</ows:Operation>
in one column. the problem will be, that we have to parse the information
every time we need them. i would prefer the storing in a relational
structure. but i think you must check it.
if have further questions - please ask.
cheers
armin
Am Freitag 10 Juli 2009 06:13:08 schrieben Sie:
> Hi Armin,
> On Thu, 2009-07-09 at 16:44 +0200, Armin Retterath wrote:
> > i am sorry, we need the post urls too, cause the specification demands
> > post for GetRecords and DescribeRecords.
> Ok - no worries - will handle the post values as well - is there a
> chance the SOAP values should be stored as well?. I'm just wondering
> whether it is possible to store both values in the schema described in
> Section 7 of the wiki? Or should I have another field to capture the
> post values?
> Anyways, I will add this in somewhere.
> Thanks
> Mifan
> > many catalogues would only implement
> > this minimal demands. 'get' is in this two cases only nice too have.
> > please see http://www.mapbender.org/CSW_Requirements point 8.
> > cheers
> > armin
> > Am Donnerstag 09 Juli 2009 07:52:39 schrieb Mifan Careem:
> > > Hi List,
> > > I've current solved the problem by storing the GET values of the
> > > operations (e.g getrecords) in the main catalog schema itself. I am
> > > currently not storing the other parameter values of the operations - if
> > > this is needed, I can handle this later on, but since currently I just
> > > need the GET URLs, I'll concentrate on this.
> > > Let me know if there are any suggestions.
> > > Thanks
> > > Mifan
> > > On Tue, 2009-07-07 at 16:05 +0530, Mifan Careem wrote:
> > > > Dear list,
> > > > My current schema to store a catalog object is here:
> > > > http://www.mapbender.org/CSW_report_week_3
> > > > I currently provide an Admin function to 'Load a Catalog'. In this, I
> > > > need to store Operation[1] values from the OperationsMetadata section
> > > > of the Catalog's GetCapabilities[2] document. What would the best way
> > > > be to store these operations sections (getrecords,describerecords
> > > > etc.), considering that I have to make use of the GET/POST values
> > > > often to make a CSW search?
> > > > Currently, I thought of this:
> > > > - Store normal catalog information in the cat table
> > > > - store Parameter names and values of the Operations in a seperate
> > > > table, like this:
> > > > INSERT INTO cat_op_conf(id,op_name,param_name,param_value) VALUES
> > > > (2,'getrecords',http_get,http://www.geodata.alterra.nl/excat/csw);
> > > > (2,'getrecords','typename','csw:Record');
> > > > etc.
> > > > Any suggestions?
> > > > [1]: <ows:Operation name="DescribeRecord">
> > > > <ows:DCP>
> > > > <ows:HTTP>
> > > > <ows:Get xlink:href="http://www.geodata.alterra.nl/excat/csw"/>
> > > > <ows:Post xlink:href="http://www.geodata.alterra.nl/excat/csw"/>
> > > > </ows:HTTP>
> > > > </ows:DCP>
> > > > <ows:Parameter name="TypeName">
> > > > <ows:Value>csw:Record</ows:Value>
> > > > </ows:Parameter>
> > > > <ows:Parameter name="OutputFormat">
> > > > <ows:Value>application/xml</ows:Value>
> > > > </ows:Parameter>
> > > > <ows:Parameter name="SchemaLanguage">
> > > > <ows:Value>XMLSCHEMA</ows:Value>
> > > > <ows:Value>http://www.w3.org/XML/Schema</ows:Value>
> > > > </ows:Parameter>
> > > > </ows:Operation>
> > > > [2]:
> > > > http://www.geodata.alterra.nl/excat/csw?request=GetCapabilities&servi
> > > >ce=C SW
> > > > Thanks
> > > > Mifan
> > > _______________________________________________
> > > Mapbender_dev mailing list
> > > Mapbender_dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
Im Auftrag
Armin Retterath
beim
56073 Koblenz
More information about the Mapbender_dev
