[Mapbender-dev] Re: Catalog Schema and Storing Op values
Mifan Careem mifan at opensource.lk
Mon Jul 13 02:03:04 EDT 2009
Hi Armin, List,
On Fri, 2009-07-10 at 09:31 +0200, Armin Retterath wrote:
> the schema i described in part 7 was only a hint ;-). i know that there is a
> problem when there are the two bindings http and soap. there are many urls to
> handle with. maybe we can split the soap binding from the http and create a
> new table 'cat_op_soap' for it? maybe the schema would be something  like :
> fkey_cat_id, cat_op_getcapabilities, ...
I did make some changes to the Schema you had suggested. I've already
added another table to handle the multiple values (get,post,soap), which
looks quite similar to what you suggest below - I mentioned this in my
last email, but then proceeded with handling the GET case only for the
time being. I will try to use this extra table (cat_op_conf:
(fkey_cat_id,param_name,param_value)) to store the multiple URLs.
> an other possibility is to store the whole xml part:
I agree with you on storing in a relational schema instead of storing
the whole component of the XML - since the URL would be retrieved often,
I guess having to parse the XML each time would be inefficient. Thus,
I'll try out the relational model as above.
Thanks for the confirmation.
Regards
Mifan
> Am Freitag 10 Juli 2009 06:13:08 schrieben Sie:
> > Hi Armin,
> > On Thu, 2009-07-09 at 16:44 +0200, Armin Retterath wrote:
> > > i am sorry, we need the post urls too, cause the specification demands
> > > post for  GetRecords and DescribeRecords.
> > Ok - no worries - will handle the post values as well - is there a
> > chance the SOAP values should be stored as well?. I'm just wondering
> > whether it is possible to store both values in the schema described in
> > Section 7 of the wiki? Or should I have another field to capture the
> > post values?
> > Anyways, I will add this in somewhere.
> > Thanks
> > Mifan
> > > many catalogues would only implement
> > > this minimal demands. 'get' is in this two cases only nice too have.
> > > please see http://www.mapbender.org/CSW_Requirements point 8.
> > > cheers
> > > armin
> > > Am Donnerstag 09 Juli 2009 07:52:39 schrieb Mifan Careem:
> > > > Hi List,
> > > > I've current solved the problem by storing the GET values of the
> > > > operations (e.g getrecords) in the main catalog schema itself. I am
> > > > currently not storing the other parameter values of the operations - if
> > > > this is needed, I can handle this later on, but since currently I just
> > > > need the GET URLs, I'll concentrate on this.
> > > > Let me know if there are any suggestions.
> > > > Thanks
> > > > Mifan
> > > > On Tue, 2009-07-07 at 16:05 +0530, Mifan Careem wrote:
> > > > > Dear list,
> > > > > My current schema to store a catalog object is here:
> > > > > http://www.mapbender.org/CSW_report_week_3
> > > > > I currently provide an Admin function to 'Load a Catalog'. In this, I
> > > > > need to store Operation[1] values from the OperationsMetadata section
> > > > > of the Catalog's GetCapabilities[2] document. What would the best way
> > > > > be to store these operations sections (getrecords,describerecords
> > > > > etc.), considering that I have to make use of the GET/POST values
> > > > > often to make a CSW search?
> > > > > Currently, I thought of this:
> > > > > - Store normal catalog information in the cat table
> > > > > - store Parameter names and values of the Operations in a seperate
> > > > > table, like this:
> > > > > INSERT INTO cat_op_conf(id,op_name,param_name,param_value) VALUES
> > > > > (2,'getrecords',http_get,http://www.geodata.alterra.nl/excat/csw);
> > > > > (2,'getrecords','typename','csw:Record');
> > > > > etc.
> > > > > Any suggestions?
> > > > > [1]: <ows:Operation name="DescribeRecord">
> > > > > <ows:DCP>
> > > > > <ows:HTTP>
> > > > > <ows:Get xlink:href="http://www.geodata.alterra.nl/excat/csw"/>
> > > > > <ows:Post xlink:href="http://www.geodata.alterra.nl/excat/csw"/>
> > > > > </ows:HTTP>
> > > > > </ows:DCP>
> > > > > <ows:Parameter name="TypeName">
> > > > > <ows:Value>csw:Record</ows:Value>
> > > > > </ows:Parameter>
> > > > > <ows:Parameter name="OutputFormat">
> > > > > <ows:Value>application/xml</ows:Value>
> > > > > </ows:Parameter>
> > > > > <ows:Parameter name="SchemaLanguage">
> > > > > <ows:Value>XMLSCHEMA</ows:Value>
> > > > > <ows:Value>http://www.w3.org/XML/Schema</ows:Value>
> > > > > </ows:Parameter>
> > > > > </ows:Operation>
> > > > > [2]:
> > > > > http://www.geodata.alterra.nl/excat/csw?request=GetCapabilities&servi
> > > > >ce=C SW
> > > > > Thanks
> > > > > Mifan
> > > > _______________________________________________
> > > > Mapbender_dev mailing list
> > > > Mapbender_dev at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
