[Mapbender-dev] [gsoc09] UserEditor
Christoph Baudson christoph.baudson at wheregroup.com
Wed Jul 15 05:04:31 EDT 2009
Karim Malhas schrieb:
> Dear dev.
> At http://karim.malhas.de/gsoc09/mapbender/http/ you can see the furst
> user editor that use mapbender_2.7 modules.
Hehe...tried to log in as root.
"Permission denied. Login failed 3 times. Your account has been
deactivated. Please contact your administrator!"
Did I miss the credentials?
Thanks,
Christoph
> There are of course some issues (to avoid duplication):
> - needs a delete button,
> - the 'save' button should be grayed out if there are no changes,
> - the listfilter doesn't work right.
> - changing the username does not work
> Comments are welcome.
> Regards,
> Karom
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
