[Mapbender-dev] Re: wfs gazetteer with umn mapserver wfs
Christoph Baudson christoph.baudson at wheregroup.com
Wed Jul 29 03:25:19 EDT 2009
Michael Schulz schrieb:
> Hi Michael,  ;-)
> another approach would be to search with xpath for
> "gml:featureMember", and then feed the firstChild, which is always the
> featuretype to the featuretype parser ... sth. like that:
> $gmlFeatureMembers = $gmlDoc->xpath("//gml:featureMember");
> if (count($gmlFeatureMembers) > 0) {
> 	foreach ($gmlFeatureMembers as $gmlFeatureMember) {
> 		$gmlfeatureMember_dom = dom_import_simplexml($gmlFeatureMember);
> 		$feature = new Feature();
> 		$this->parseFeature($gmlfeatureMember_dom->firstChild, $feature, $wfsConf);
> 		if (isset($feature->geometry)) {
> 			$gml->featureCollection->addFeature($feature);
This looks like a more generic approach...are you willing to integrate
this into the 2.6 branch?
But I guess we should consult mschulz first ;-)
Thanks for your help
Christoph
> Actually, I wondered why e.g. QGIS had no problems to load a UMN
> WFS... so that's the reason.
> Cheers, mandsch
> 2009/7/28 Michael Schulz <mschulz at webgis.de>:
>> Hi Devs,
>> after some detours and especially after some valuable hints from
>> Christoph on irc I came to this workaround, for the described problem,
>> when using UMN as WFS-Server and getting no results from WFS-Gazatteer
>> requests, because there is an obscure namespace problem with UMN-WFS
>> (it breaks down to: umn gives a featuretype name in the getcaps
>> without ns, this is stored in the mapbender db, when parsing
>> getfeature request, that stored value is used to go through the
>> getfeature result xml, that unfortunately now uses a namespace "ms:",
>> so mapbender code won't find any features).
>> My workaround is to ignore namespaces when searching for the result
>> features, by using the xpath function local-name(). This can be
>> applied in class_gml_factory around line 20, instead of:
>>  $gmlFeatureMembers = $gmlDoc->xpath("//" . $featureType->name);
>> you could write:
>>  $admin = new administration();
>>  $gmlFeatureMembers = $gmlDoc->xpath("//*[local-name()='".
>> $admin->sepNameSpace($featureType->name)."']" );
>> This ignores the namespace, but certainly leaves the xml untouched.
>> I've tested it with UMN and Geoserver. If someone wants to give it a
>> try, I'll be happy for any feedback.
>> Cheers, Michael
>> 2009/7/14 Michael Schulz <mschulz at webgis.de>:
>>> Hi,
>>> I have a strange problem when using umn mapserver as a wfs-server for
>>> a gazetteer search. The problem is that the featuretype is announced
>>> in get getCaps as
>>> <Name>meinFeatureType</Name>.
>>>  When actually searching and issueing the getfeature request, the
>>> result is returned with featuremembers with the default ms namespace:
>>> <gml:featureMember><ms:meinFeatureType
>>> fid="meinFeatureType.007">...</gml:featureMember>.
>>> The problem is now that in the gml classes, the returned gml is
>>> accessed with the xpath function searching for the featuretype name as
>>> recieved from the getCapabilities response and since this name has no
>>> namespace it won't find the featuremembers...
>>> Is this a mapserver wfs misconfiguration on my side (i tried with
>>> wms_namespace_prefix ...) or a mapserver wfs bug or a mapbender bug?
>>> When using geoserver the featuretype namespace is also returned in the
>>> getcapabilities response.
>>> Thanks for your hints ... Michael
>>> Aufwind durch Wissen!
>>> Qualifizierte Open Source Schulungen bei der
>>> http://www.foss-akademie.de/
>>> Michael Schulz
>>> in medias res
>>> Gesellschaft für Informationstechnologie mbH
>>> +++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
>>> Schwimmbadstraße 2
>>> D-79100  Freiburg i. Br.
>>> Tel:  +49 (0)761 705798-102
>>> Tel:  +49 (0)761 705798-0
>>> Fax: +49 (0)761 705798-09
>>> http://www.webgis.de / http://www.zopecms.de
>>> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>>> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
>> Michael Schulz
>> in medias res
>> Schwimmbadstraße 2
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
