[Mapbender-dev] Re: wfs gazetteer with umn mapserver wfs
Michael Schulz mschulz at webgis.de
Wed Jul 29 04:16:22 EDT 2009
Hi Christoph,
yes, I also agree, that this is a more generic approach and I'd be
willing to integrate that into 2.6 branch. Although I'd be happy to
have someone with strong-WFS background check this approach.
Cheers, Michael
2009/7/29 Christoph Baudson <christoph.baudson at wheregroup.com>:
> Michael Schulz schrieb:
>> Hi Michael,  ;-)
>> another approach would be to search with xpath for
>> "gml:featureMember", and then feed the firstChild, which is always the
>> featuretype to the featuretype parser ... sth. like that:
>> $gmlFeatureMembers = $gmlDoc->xpath("//gml:featureMember");
>> if (count($gmlFeatureMembers) > 0) {
>>        foreach ($gmlFeatureMembers as $gmlFeatureMember) {
>>                $gmlfeatureMember_dom =
>> dom_import_simplexml($gmlFeatureMember);
>>                $feature = new Feature();
>>                $this->parseFeature($gmlfeatureMember_dom->firstChild,
>> $feature, $wfsConf);
>>                if (isset($feature->geometry)) {
>>                        $gml->featureCollection->addFeature($feature);
> This looks like a more generic approach...are you willing to integrate this
> into the 2.6 branch?
> But I guess we should consult mschulz first ;-)
> Thanks for your help
> Christoph
>> Actually, I wondered why e.g. QGIS had no problems to load a UMN
>> WFS... so that's the reason.
>> Cheers, mandsch
>> 2009/7/28 Michael Schulz <mschulz at webgis.de>:
>>> Hi Devs,
>>> after some detours and especially after some valuable hints from
>>> Christoph on irc I came to this workaround, for the described problem,
>>> when using UMN as WFS-Server and getting no results from WFS-Gazatteer
>>> requests, because there is an obscure namespace problem with UMN-WFS
>>> (it breaks down to: umn gives a featuretype name in the getcaps
>>> without ns, this is stored in the mapbender db, when parsing
>>> getfeature request, that stored value is used to go through the
>>> getfeature result xml, that unfortunately now uses a namespace "ms:",
>>> so mapbender code won't find any features).
>>> My workaround is to ignore namespaces when searching for the result
>>> features, by using the xpath function local-name(). This can be
>>> applied in class_gml_factory around line 20, instead of:
>>>  $gmlFeatureMembers = $gmlDoc->xpath("//" . $featureType->name);
>>> you could write:
>>>  $admin = new administration();
>>>  $gmlFeatureMembers = $gmlDoc->xpath("//*[local-name()='".
>>> $admin->sepNameSpace($featureType->name)."']" );
>>> This ignores the namespace, but certainly leaves the xml untouched.
>>> I've tested it with UMN and Geoserver. If someone wants to give it a
>>> try, I'll be happy for any feedback.
>>> Cheers, Michael
>>> 2009/7/14 Michael Schulz <mschulz at webgis.de>:
>>>> Hi,
>>>> I have a strange problem when using umn mapserver as a wfs-server for
>>>> a gazetteer search. The problem is that the featuretype is announced
>>>> in get getCaps as
>>>> <Name>meinFeatureType</Name>.
>>>>  When actually searching and issueing the getfeature request, the
>>>> result is returned with featuremembers with the default ms namespace:
>>>> <gml:featureMember><ms:meinFeatureType
>>>> fid="meinFeatureType.007">...</gml:featureMember>.
>>>> The problem is now that in the gml classes, the returned gml is
>>>> accessed with the xpath function searching for the featuretype name as
>>>> recieved from the getCapabilities response and since this name has no
>>>> namespace it won't find the featuremembers...
>>>> Is this a mapserver wfs misconfiguration on my side (i tried with
>>>> wms_namespace_prefix ...) or a mapserver wfs bug or a mapbender bug?
>>>> When using geoserver the featuretype namespace is also returned in the
>>>> getcapabilities response.
>>>> Thanks for your hints ... Michael
>>>> Aufwind durch Wissen!
>>>> Qualifizierte Open Source Schulungen bei der
>>>> http://www.foss-akademie.de/
>>>> Michael Schulz
>>>> in medias res
>>>> Gesellschaft für Informationstechnologie mbH
>>>> +++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
>>>> Schwimmbadstraße 2
>>>> D-79100  Freiburg i. Br.
>>>> Tel:  +49 (0)761 705798-102
>>>> Tel:  +49 (0)761 705798-0
>>>> Fax: +49 (0)761 705798-09
>>>> http://www.webgis.de / http://www.zopecms.de
>>>> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>>>> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
>>> Michael Schulz
>>> in medias res
>>> Schwimmbadstraße 2
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu
> _______________________________________
> W h e r e G r o u p GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 15
> Fax: +49 (0)228 / 90 90 38 - 11
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Schwimmbadstraße 2
More information about the Mapbender_dev mailing list
