[Mapbender-dev] motion: change attribute "extent" of map
Michael Schulz mschulz at webgis.de
Tue Jun 2 12:32:42 EDT 2009
Hi Christoph,
I second this motion and vote +1.
Cheers, Michael
2009/6/2 Astrid Emde <astrid.emde at wheregroup.com>:
> Christoph Baudson schrieb:
>> Currently, this is a string containing four comma-separated coordinates.
>> This is hard to use, whenever you want to perform an operation on the
>> extent, you have to split the string and use parseFloat. There is also no
>> way to register an event with the setting of the extent, because it's not a
>> function.
>> At the development sprint in Hannover Peter and I discussed the
>> implementation of a restricted extent. For this, we concluded, using the
>> Extent object as attribute (and no longer the string) would be necessary. I
>> am changing this in trunk, if this motion passes. The changes would include
>> (1) The extent attribute is currently *set* by
>> map.extent = "a,b,c,d";
>> The new version would use this syntax
>> map.extent = new Extent(a,b,c,d);
>> (2) The extent attribute is currently *read* by
>> map.extent
>> which is a string "a,b,c,d". The new version would use this syntax
>> map.extent.toString();
>> and return the same string "a,b,c,d".
>> All custom modules would have to use these changes as well, which will be
>> important when updating. I'll only change the modules in Mapbender trunk.
>> Please second this motion and vote.
>> Christoph
> Hi Christoph,
> this idea sound good.
> +1 from  me
> Astrid
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_dev mailing list
