[Mapbender-dev] motion: change attribute "extent" of map
    Astrid Emde
    astrid.emde at wheregroup.com
    Tue Jun  2 12:11:33 EDT 2009
Christoph Baudson schrieb:
> Currently, this is a string containing four comma-separated
> coordinates. This is hard to use, whenever you want to perform an
> operation on the extent, you have to split the string and use
> parseFloat. There is also no way to register an event with the setting
> of the extent, because it's not a function.
> At the development sprint in Hannover Peter and I discussed the
> implementation of a restricted extent. For this, we concluded, using
> the Extent object as attribute (and no longer the string) would be
> necessary. I am changing this in trunk, if this motion passes. The
> changes would include
> (1) The extent attribute is currently *set* by
> map.extent = "a,b,c,d";
> The new version would use this syntax
> map.extent = new Extent(a,b,c,d);
> (2) The extent attribute is currently *read* by
> map.extent
> which is a string "a,b,c,d". The new version would use this syntax
> map.extent.toString();
> and return the same string "a,b,c,d".
> All custom modules would have to use these changes as well, which will
> be important when updating. I'll only change the modules in Mapbender
> trunk.
> Please second this motion and vote.
> Christoph
Hi Christoph,
 this idea sound good.
+1 from  me
Astrid
More information about the Mapbender_dev
