[Mapbender-dev] Re: LC_MESSAGES and Windows (again)
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Mar 6 05:20:10 EST 2009
Thanks for your input, Thomas. We should definitely have a workaround. I
have googled some more, and didn't find any solution to this (but a lot
of people having the same trouble).
I think the easiest solution might be replacing line 27 in
core/globalSettings.php by
if (!defined('LC_MESSAGES')) define('LC_MESSAGES', LC_CTYPE);
Thomas, could you try if this has the same effect as your workaround?
BTW, re-reading PHP.net's page for setlocale has a discouraging warning:
"The locale information is maintained per process, not per thread. If
you are running PHP on a multithreaded server api like IIS or Apache on
Windows you may experience sudden changes of locale settings while a
script is running although the script itself never called *setlocale()*
itself. This happens due to other scripts running in different threads
of the same process at the same time changing the processwide locale
using *setlocale()*."
So using gettext in Windows with PHP is not really recommended.
Christoph
Thomas Baschetti schrieb:
>>> OK, no PHP-Error, but still language support under windows seems to
>>> fail:
>>> $selectedLocale = setlocale(LC_MESSAGES, $locale);
>>> $e = new Mb_notice("setlocal fuer LC_MESSAGES " . LC_MESSAGES . "
>>> auf locale: >" . $selectedLocale . "<");
>>> results in
>>> Notice: setlocal fuer LC_MESSAGES 6 auf locale: ><
>>> Can anyone confirm this?
>> Yes, I've experience the same problem...but no solution yet. Where
>> are the Windows gurus?
>> I will re-open the ticket.
> if i see it correctly, we are using lc_messages mainly for _determing_
> the right language, right?
> So why not just use e.g. LC_CTYPE?
> Or something like:
> if (defined('LC_MESSAGES')){
> else{
> $saveme=setlocale(LC_CTYPE,0);
> $selectedLocale=setlocale(LC_CTYPE,$locale);
> $saveme=setlocale(LC_CTYPE,$saveme);
> if we must preserve LC_CTYPE.
> Ciao
> Thomas
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
