[Mapbender-dev] Re: LC_MESSAGES and Windows (again)
Thomas Baschetti Thomas.Baschetti at gmx.de
Fri Mar 6 07:01:45 EST 2009
Christoph Baudson schrieb:
> I think the easiest solution might be replacing line 27 in
> core/globalSettings.php by
> if (!defined('LC_MESSAGES')) define('LC_MESSAGES', LC_CTYPE);
> Thomas, could you try if this has the same effect as your workaround?
ok, will test it over the weekend.
> So using gettext in Windows with PHP is not really recommended.
short verion: windows ist not really recommended ;-)
Ciao
Thomas
More information about the Mapbender_dev mailing list
