[Mapbender-dev] Re: LC_MESSAGES and Windows (again)
Thomas Baschetti
Thomas.Baschetti at gmx.de
Mon Mar 9 12:04:04 EDT 2009
Christoph Baudson schrieb:
> I think the easiest solution might be replacing line 27 in
> core/globalSettings.php by
> if (!defined('LC_MESSAGES')) define('LC_MESSAGES', LC_CTYPE);
> Thomas, could you try if this has the same effect as your workaround?
tested, seems to be working without problems, i think we can go like you
suggested.
Ciao
Thomas
More information about the Mapbender_dev
