[Mapbender-dev] Re: [Mapbender] #469: Legends from Geoserver do not show up
Mapbender mapbender_dev at lists.osgeo.org
Fri May 15 04:30:38 EDT 2009
  Reporter:  teac            |       Owner:  dev
      Type:  defect          |      Status:  new
  Priority:  major           |   Milestone:  2.6 release
 Component:  user interface  |     Version:  2.6 rc1
Resolution:                  |    Keywords:  Getlegendgraphic Geoserver legend
Comment (by teac):
 Hi mschulz,
 thanks for your reply. I´ve checked your points: the style which is
 assigned to the layer is correct. The layername in the capabilities-
 document is unique. There are no child-layers in the WMS. The Problem
 still exists.
 But I figured out a workaround: In table "layerstyle" -> column "name", I
 set the entry for the specific layer to "default". Then the legend is ok.
 Here´s the SQL:
 UPDATE layer_style
 SET name = 'default'
 WHERE fkey_layer_id = 18384;
 Perhaps this helps to fix the problem.
 Regards
 teac
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/469#comment:2>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
