[Mapbender-dev] I18n tutorial
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Wed Nov 18 11:23:08 EST 2009
Hi there,
we have prepared a new i18n mechanism for Mapbender 2.7.
There is a new module i18n, which collects content from other modules,
and only performs a single AJAX request to retrieve the translations
from the server side. In Mapbender 2.6, each module handled i18n
individually.
Note: This module only handles gettext translations! There is no
solution for database solutions. However, database translations are
somehow deprecated. I guess we will aim to be gettext-only asap.
Adding i18n to your module is much easier now. There is also a new
tutorial [1] which should explain it all. Take a look, and let us know
if there are errors, or just correct them yourself.
Thanks,
Christoph
[1] http://www.mapbender.org/Internationisation_tutorial
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
