[Mapbender-dev] [Mapbender] #563: resizeMapsize - keep scale when resize
Mapbender mapbender_dev at lists.osgeo.org
Wed Nov 25 11:02:19 EST 2009
 Reporter:  astrid_emde     |       Owner:  dev
     Type:  enhancement     |      Status:  new
 Priority:  major           |   Milestone:  2.7 release
Component:  user interface  |     Version:  2.6
 Keywords:                  |
 * when you use the Button resizeMapsize to make your map fit to the
 browser window. Mapbender resizes mapframe1 but changes the scale.
  * it woulde be a nice feature if the scale would stay the same then
 before.
 The normal usecase is, that you are in a special area in the scale you
 prefer and you just want to have a bigger mapframe and you don't want to
 change the scale.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/563>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
