[Mapbender-dev] [Mapbender] #542: map refresh should be run
automatically after Opacity up / down
mapbender_dev at lists.osgeo.org
Mon Oct 5 04:46:58 EDT 2009
#542: map refresh should be run automatically after Opacity up / down
Reporter: teac | Owner: dev
Type: module | Status: new
Priority: major | Milestone: 2.7 release
Component: treeGDE | Version: 2.6
Keywords: Opacity up / down |
In standard gui of Mapbender 2.6 it´s possible to increase and reduce the
opacity for a WMS using the context menu in the TreeGDE. Unfortunately
this has no direct effect on the Map. You have to use "repaint" to get the
desired effect.
It would be more user-friendly, to trigger an automatic map refresh after
adjusting the opacity.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/542>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
