[Mapbender-dev] Amplification of the Mapbender Installation Skript
Christoph Baudson
christoph.baudson at wheregroup.com
Tue Sep 15 06:22:22 EDT 2009
Vera Schulze schrieb:
> Hi Christoph,
> ok, I updated the file install_2.6.sh like you mentioned.
There is also a install_2.6.bat for Windows. Please check it as well.
Thanks!
Christoph
> thanks, Vera
>>> Hi Dev-List,
>>> I added an update sql (update_2.6rc2_to_2.6_pgsql_UTF-8.sql) for
>>> Mapbender migration 2.6rc2 to 2.6 to the Mapbender svn. It contains
>>> updates and inserts for the table translations needed for the I18N.
>> Hi Vera,
>> please add your changes to the file
>> "update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql"
>> Then rename the file to "update_2.6rc1_to_2.6_pgsql_UTF-8.sql"
>> There is no rc2 for Mapbender 2.6, it was just named under the
>> assumption we would have one.
>> I guess you can update the install scripts yourself, just look for
>> the appropriate file name and update it (as described above). Consult
>> me if you are blocked.
>> Thanks for your contribution!
>> Christoph
>>> For this reason an amplification of the Mapbender Installation
>>> Skript is needed.
>>> Somebody who likes do to that?
>>> Regards,
>>> Vera
INTERGEO 2009
22.-24. September 2009 in Karlsruhe
Halle 1, Stand 1.417
www.intergeo.de
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
