[Mapbender-dev] Amplification of the Mapbender Installation Skript
Vera Schulze v.schulze at wheregroup.com
Tue Sep 15 05:52:09 EDT 2009
Hi Christoph,
ok, I updated the file install_2.6.sh like you mentioned.
thanks, Vera
Christoph Baudson schrieb:
> Vera Schulze schrieb:
>> Hi Dev-List,
>> I added an update sql (update_2.6rc2_to_2.6_pgsql_UTF-8.sql) for
>> Mapbender migration 2.6rc2 to 2.6 to the Mapbender svn. It contains
>> updates and inserts for the table translations needed for the I18N.
> Hi Vera,
> please add your changes to the file
> "update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql"
> Then rename the file to "update_2.6rc1_to_2.6_pgsql_UTF-8.sql"
> There is no rc2 for Mapbender 2.6, it was just named under the
> assumption we would have one.
> I guess you can update the install scripts yourself, just look for the
> appropriate file name and update it (as described above). Consult me
> if you are blocked.
> Thanks for your contribution!
> Christoph
>> For this reason an amplification of the Mapbender Installation Skript
>> is needed.
>> Somebody who likes do to that?
>> Regards,
>> Vera
INTERGEO 2009
22.-24. September 2009 in Karlsruhe
Halle 1, Stand 1.417
www.intergeo.de
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - **
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
