[Mapbender-dev] install script handling
Christoph Baudson
christoph.baudson at wheregroup.com
Tue Sep 15 10:02:32 EDT 2009
Hmmm I just found out that the install script in trunk is not up to date
The script in 2.6 seems to be the current script. Will try again.
Christoph Baudson schrieb:
> Dear community,
> I'm still somehow puzzled what would be the standard way to install
> Mapbender:
> (1) which user shall run the installer?
> (2) which db user shall be used?
> Here are my thoughts, please help me get on track
> (1) the user should be allowed to grant write permissions to the web
> user, so the script must be run as a superuser
> (2) the success of the database access depends upon the settings in
> pg_hba.conf (in PostgreSQL). I assume the default is "ident", which
> leads me to the assumption, that there must be a corresponding db user
> to the os user. I always create a superuser named after my os user, so
> I don't have a problem. But if I want to use the db user "postgres",
> this won't work. When does PostgreSQL ask for a password? And if so,
> does it require the password for every single SQL file?
> The installer should be foolproof and self-explanatory. Please help.
> Thanks, Christoph
INTERGEO 2009
22.-24. September 2009 in Karlsruhe
Halle 1, Stand 1.417
www.intergeo.de
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
