[Mapbender-dev] json_encode, ISO-8859-1, Ticket 171
Christoph Baudson christoph.baudson at wheregroup.com
Tue Sep 15 10:15:08 EDT 2009
Thomas Baschetti schrieb:
> Hi,
> while exploring http://trac.osgeo.org/mapbender/ticket/171
> i got a little bit stuck.
> The problem seems to in
> mod_addWMSfromfilteredList_server.php
> the line
> $output = $json->encode($resultObj);
> which fails if the database is not UTF-8 but ISO-8859-1
> see http://de.php.net/manual/en/function.json-encode.php
> "This function only works with UTF-8 encoded data." If you use e.g.
> german umlauts in ISO you will get "Oberfl" instead of "Oberfläche".
> So, converting values to UTF-8 is necessary, but when and where?
> Right after retrieving the values from the database or just before
> using json_encode? And are other files affected, too?
Hi Thomas,
please check the method "encode" of http/classes/class_json.php
We could make the change there...
Hope this helps
Christoph
> Any hints?
> Ciao
> Thomas
INTERGEO 2009
22.-24. September 2009 in Karlsruhe
Halle 1, Stand 1.417
www.intergeo.de
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
