[Mapbender-dev] json_encode, ISO-8859-1, Ticket 171
Thomas Baschetti
info at thomas-baschetti.de
Tue Sep 15 12:35:26 EDT 2009
Christoph Baudson schrieb:
> Thomas Baschetti schrieb:
>> Hi,
>> while exploring http://trac.osgeo.org/mapbender/ticket/171
>> i got a little bit stuck.
>> The problem seems to in
>> mod_addWMSfromfilteredList_server.php
>> the line
>> $output = $json->encode($resultObj);
>> which fails if the database is not UTF-8 but ISO-8859-1
>> see http://de.php.net/manual/en/function.json-encode.php
>> "This function only works with UTF-8 encoded data." If you use e.g.
>> german umlauts in ISO you will get "Oberfl" instead of "Oberfläche".
>> So, converting values to UTF-8 is necessary, but when and where?
>> Right after retrieving the values from the database or just before
>> using json_encode? And are other files affected, too?
> Hi Thomas,
> please check the method "encode" of http/classes/class_json.php
> We could make the change there...
> Hope this helps
> Christoph
ok,
i tried the following in http/classes/class_json.php
(see http://de.php.net/manual/de/function.json-encode.php#72450)
-------snipp----------------------
* Converts incoming to UTF-8 for json_encode
private function json_fix_charset($var)
if (is_array($var)) {
$new = array();
foreach ($var as $k => $v) {
$new[$this->json_fix_charset($k)] =
$this->json_fix_charset($v);
$var = $new;
} elseif (is_object($var)) {
$vars = get_class_vars(get_class($var));
foreach ($vars as $m => $v) {
$var->$m = $this->json_fix_charset($v);
} elseif (is_string($var)) {
$var = utf8_encode($var);
return $var;
* Encodes an object to JSON
public function encode($anObject) {
if ($this->library == JSON_PEAR) {
$pear = new Services_JSON();
$e = new mb_notice("using PEAR JSON");
return $pear->encode($anObject);
$e = new mb_notice("using native JSON");
return json_encode($anObject);
//return json_encode($this->json_fix_charset($anObject));
which works for Add WMS from filtered List (hooray), and
breaks "Load WMC from list" (boo), because now all is converted to UTF-8...
Hm, i have to think about this a little more...
Ciao
Thomas
Thomas Baschetti - Systemanalyse Geographische Informationssysteme
Hakenstraße 8D
49074 Osnabrück
Tel: 0541 25 91 90 | mobil 01577 189 25 91
E-Mail: info at thomas-baschetti.de
www.thomas-baschetti.de
Ust-IdNr.: DE264355072
More information about the Mapbender_dev
