[Mapbender-dev] [Mapbender] #531: TreeGDE: Checkboxes are out of
sync with map
mapbender_dev at lists.osgeo.org
Wed Sep 16 04:43:03 EDT 2009
#531: TreeGDE: Checkboxes are out of sync with map
Reporter: christoph | Owner: dev
Type: defect | Status: new
Priority: major | Milestone: 2.7 release
Component: treeGDE | Version: 2.5
Keywords: |
If you quickly check/uncheck/check a WMS' visibility, the visibility in
the map no longer correspondends to the treeGDE status.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/531>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
