[Mapbender-dev] install script handling
Christoph Baudson
christoph.baudson at wheregroup.com
Tue Sep 15 13:15:00 EDT 2009
Thomas Baschetti schrieb:
> Hi,
> Christoph Baudson schrieb:
>> I'm still somehow puzzled what would be the standard way to install
>> Mapbender:
>> (1) which user shall run the installer?
>> (2) which db user shall be used?
>> Here are my thoughts, please help me get on track
>> (1) the user should be allowed to grant write permissions to the web
>> user, so the script must be run as a superuser
> not nice, i don't like this. I try NOT to start any script as a
> superuser unless it is really, really, really necessary.
>> (2) the success of the database access depends upon the settings in
>> pg_hba.conf (in PostgreSQL). I assume the default is "ident", which
>> leads me to the assumption, that there must be a corresponding db
>> user to the os user. I always create a superuser named after my os
>> user, so I don't have a problem. But if I want to use the db user
>> "postgres", this won't work. When does PostgreSQL ask for a password?
>> And if so, does it require the password for every single SQL file?
> First to say, "ident" is not default on windows (who uses windows,
> anyway...)
> If using password-authentification (md5), psql will ask whenever it
> connects to the database. So yes, for every single SQL-file (+1 extra
> for createdb)
> You can prevent this by
> - setting an environment var "pgpassword" which is considered a
> security risk,
> - using a file ~/.pgpass which consists of connect-strings:
> host:port:database:username:password
You put a lot of thought into it, thanks. Will have to try it myself.
>> The installer should be foolproof and self-explanatory. Please help.
> and have a gui.
> I think installation should be like:
> - download mapbender
> - unzip it in your webdirectory
> - go to http://server/mapbenderpath
> - fill in some questions (database, server, ...)
> - magic happens
> - mapbender is up and running
> The actual install-scripts are only a temporary solution, imho.
Yes, you're right.
> Other projects get this done (mediawiki, drupal...), i think we can
> get this done, too.
> Other opinions?
> Ciao
> Thomas
INTERGEO 2009
22.-24. September 2009 in Karlsruhe
Halle 1, Stand 1.417
www.intergeo.de
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
