[Mapbender-dev] GSoC 2010 Project - RESTful API for Mapbender [RFC]
Vikash Banjara vikashbanjara at gmail.com
Mon Apr 26 16:48:50 EDT 2010
Thanks to all of you.
I am officially accepted for the GSoC 2010. I will work on "Restful API for
Mapbender".
P.S.: I will not be available before 6th May, because of exams at the
university. I will start soon after the exams are over.
Regards
Vikash
On Tue, Apr 6, 2010 at 5:45 PM, Vikash Banjara <vikashbanjara at gmail.com>wrote:
> Seven,
> Thanks for your suggestions. I have made proper changes to the application.
> You can check out once again.
> On Tue, Apr 6, 2010 at 4:14 PM, Seven (aka Arnulf) <seven at arnulf.us>wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Vikash Banjara wrote:
>> > Hello devs,
>> > I have submitted my proposal for GSoC 2010 project - RESTful API for
>> > Mapbender at http://socghop.appspot.com under the Organization OSGeo.
>> > Please  go through the proposal and suggest me changes. I still have
>> time
>> > till 9th April 2010 to edit the proposal. I will be really grateful to
>> you
>> > people for reviewing the application.
>> > Anticipating response,
>> > Regards
>> > Vikash
>> Vikash,
>> thank you for submitting the proposal. Before submitting my comments to
>> the GSoC site please consider the following details:
>> I have a question and suggestion wrt the work plan. Why do you want to
>> first implement the client side request of the API and then the server
>> side?
>> I was wrong when I said that client side should be designed first. Logical
> thing will be to design the server side processing.
> Regards
> Vikash
>> We should also clean out terminology, what is the client side and what
>> is the server side, what is the back end. We could add this as a work
>> package to the first three week design period.
>> After GSoC starts - First three weeks -
>> Add:
>> ... "Update the Glossary of the project to describe the use of the terms
>> "client", "server", "back end", "application", etc. in the context of
>> the project"
>> After first three weeks to Mid-term -
>> Add:
>> ... "We will use a test driven development method and follow the Scrum
>> process with daily scrums (as the availability of mentor and student
>> will allow).
>> Please consider answering for this question:
>> "How does your SoC task benefit the OSGeo member project, and more
>> generally the OSGeo Foundation as a whole?"
>> Suggestion:
>> "The REST-API project will make it easier to integrate Mapbender with
>> other projects. It will also allow machine access to the management back
>> end data and improve the use of the project as centralized management
>> back end for spatial data infrastructures. This will further improve the
>> USP of the project."
>> "Please provide details of previous GIS experience"
>> I suggest you say: "None". This will not be a problem for us (as you
>> already say further down). The project and tasks involved do not require
>> you to have up front knowledge of GIS.
>> I will talk over the proposal with Christoph but as far as I am
>> concerned this is already a good proposal. I am happy with it.
>> Best regards,
>> Arnulf.
>> Arnulf Christl
>> Exploring Space, Time and Mind
>> http://arnulf.us
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.9 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>> iEYEARECAAYFAku7EIUACgkQXmFKW+BJ1b0nNACfTBiLwnHBQ+ATT0gEhJ1oTha4
>> SOkAn0nmFrIVS4OUXJ9ign+rV1oi58VC
>> =SZ5N
>> -----END PGP SIGNATURE-----
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
URL: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20100427/f91a1a02/attachment.html
More information about the Mapbender_dev mailing list
