[Mapbender-dev] GSoC 2010 Project - RESTful API for Mapbender
[RFC]
Vikash Banjara
vikashbanjara at gmail.com
Tue Apr 6 08:15:20 EDT 2010
Seven,
Thanks for your suggestions. I have made proper changes to the application.
You can check out once again.
On Tue, Apr 6, 2010 at 4:14 PM, Seven (aka Arnulf) <seven at arnulf.us> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Vikash Banjara wrote:
> > Hello devs,
> > I have submitted my proposal for GSoC 2010 project - RESTful API for
> > Mapbender at http://socghop.appspot.com under the Organization OSGeo.
> > Please go through the proposal and suggest me changes. I still have time
> > till 9th April 2010 to edit the proposal. I will be really grateful to
> you
> > people for reviewing the application.
> > Anticipating response,
> > Regards
> > Vikash
> Vikash,
> thank you for submitting the proposal. Before submitting my comments to
> the GSoC site please consider the following details:
> I have a question and suggestion wrt the work plan. Why do you want to
> first implement the client side request of the API and then the server
> side?
> I was wrong when I said that client side should be designed first. Logical
thing will be to design the server side processing.
Regards
Vikash
> We should also clean out terminology, what is the client side and what
> is the server side, what is the back end. We could add this as a work
> package to the first three week design period.
> After GSoC starts - First three weeks -
> Add:
> ... "Update the Glossary of the project to describe the use of the terms
> "client", "server", "back end", "application", etc. in the context of
> the project"
> After first three weeks to Mid-term -
> Add:
> ... "We will use a test driven development method and follow the Scrum
> process with daily scrums (as the availability of mentor and student
> will allow).
> Please consider answering for this question:
> "How does your SoC task benefit the OSGeo member project, and more
> generally the OSGeo Foundation as a whole?"
> Suggestion:
> "The REST-API project will make it easier to integrate Mapbender with
> other projects. It will also allow machine access to the management back
> end data and improve the use of the project as centralized management
> back end for spatial data infrastructures. This will further improve the
> USP of the project."
> "Please provide details of previous GIS experience"
> I suggest you say: "None". This will not be a problem for us (as you
> already say further down). The project and tasks involved do not require
> you to have up front knowledge of GIS.
> I will talk over the proposal with Christoph but as far as I am
> concerned this is already a good proposal. I am happy with it.
> Best regards,
> Arnulf.
> Arnulf Christl
> Exploring Space, Time and Mind
> http://arnulf.us
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAku7EIUACgkQXmFKW+BJ1b0nNACfTBiLwnHBQ+ATT0gEhJ1oTha4
> SOkAn0nmFrIVS4OUXJ9ign+rV1oi58VC
> =SZ5N
> -----END PGP SIGNATURE-----
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
URL: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20100406/f1a6cd84/attachment.html
More information about the Mapbender_dev
