[Mapbender-dev] Proposed changed to Application/Element relation
Karim Malhas
karim at malhas.de
Mon Feb 8 16:43:58 EST 2010
Sorry for the late reply,
> I suggest the following changes to be made in the application/element
> relation before the re-design of the "edit gui elements" dialogue takes
> place.
> (1) allow hierarchy of HTML elements
I am very much in favour of that idea.
How do do you propose we implement it ?
The first thing that comes to mind is a "parent" field in
gui_elements...
> Currently, we would have to rearrange the DOM in JS, which is a waste of
> client resources and error prone. Another upside is, this would be
> backwards compatible.
... which seems fit the backwardscompatible requirement.
> (2) add a field for php file
> the old design made sense for the classical php approach, where a php
> file created JS code. Now, we almost exclusively use AJAX. Having the
> server side listed would allow for better access control and possibly
> more flexible configuration.
Could you provide a use case? It seems to me that clientside javascript
can already call whichever url, and that each php file needs to
implement some kind of access control anyway.
Regards,
Karim
More information about the Mapbender_dev
