[Mapbender-dev] Testing
Astrid Emde astrid.emde at wheregroup.com
Tue Feb 9 01:29:58 EST 2010
Hello Karim,
we have the page "Release_guide"
http://www.mapbender.org/Release_guide
which we can follow before a new version is coming out.
Then there is the page "Test"
http://www.mapbender.org/Test.
I like your floating ideas. Maybe we can transfer them to a wiki page an
discuss them there. It will be a big goal if most of the test will run
automatically and not manual.
I added some comments.
On Mon, February 8, 2010 5:54 pm, Karim Malhas wrote:
> Dear *,
> In the IRC meeting we noticed that we have no plan for testing.
> Not even a definition what testing is, so I went to the wiki to see what
> we have.
> But appart from
> "There is no unit testing in Mapbender. This will change in the near
> future." http://www.mapbender.org/Unit_test
> I didn't find anything interesting, so I thought I'd write something up
> 1 Automated Tests
> 1.1 Unit Tests for PHP
> 1.2 Unit Tests for Javascript
> These are kind of obvious. They're a little hard to do, because they
> require witing tests, which is difficult when the Codebase already exists
> and has varying states of Quality/Coding conventions The goal here would
> be to get to a point where there are few to none (preferably none) global
> variables in a collection of classes that have a well defined interface.
> Some can already be used this way
> some others can't.
> 1.3 Unit Tests for GUIs
> Maybe we can come up with a way to test GUIs automaticaly after
> updates?
That would be a good solution
> 1.4 Services
> Should we test if the services are operational and working as
> expected? How?
> 1.5 Installation
> This could be automated in a VM.
yep
> 2. Manual Tests
> 2.1 Test GUIs
> Is this really the only manual test we have?
> We could create checklists of how to test a GUI
> 1. Log in [ ]
> 2. Open Gui [ ]
> 3. perform operation X [ ]
> Z. log out
> These checklists could be the basis of an automated test. Because
> really, we would like to do as little as possible manually.
right - this would be great.
> I am just floating ideas here, if someone as comments, please add them.
> Regards,
> Karim
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
FOSSGIS Konferenz 2010
2. - 5. März 2010 in Osnabrück
http://www.fossgis.de/konferenz
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
