[Mapbender-dev] Testing
Christoph Baudson (Wheregroup)
christoph.baudson at wheregroup.com
Tue Feb 16 03:43:31 EST 2010
Thanks Karim for your thoughts.
I think the first step will be to create a build script and run the
current unit testing code in it. Only then will the tests be executed on
a regular basis and we will have a motivation to write tests. I talked
to our sponsor about this, and I'm optimistic we get some time to do
this step in the near future.
Did we discuss a testing framework for JS? I think Karim took a glance
at envJS, while I peeked at QUnit which relies on jQuery.
We should think about putting testing on our road map for the next quarter.
Christoph
Karim Malhas schrieb:
> Dear *,
> In the IRC meeting we noticed that we have no plan for testing.
> Not even a definition what testing is, so I went to the wiki to see what
> we have.
> But appart from
> "There is no unit testing in Mapbender. This will change in the near
> future."
> http://www.mapbender.org/Unit_test
> I didn't find anything interesting, so I thought I'd write something up
> 1 Automated Tests
> 1.1 Unit Tests for PHP
> 1.2 Unit Tests for Javascript
> These are kind of obvious. They're a little hard to do, because they
> require witing tests, which is difficult when the Codebase already
> exists and has varying states of Quality/Coding conventions
> The goal here would be to get to a point where there are few to none
> (preferably none) global variables in a collection of classes that
> have a well defined interface. Some can already be used this way
> some others can't.
> 1.3 Unit Tests for GUIs
> Maybe we can come up with a way to test GUIs automaticaly after
> updates?
> 1.4 Services
> Should we test if the services are operational and working as
> expected? How?
> 1.5 Installation
> This could be automated in a VM.
> 2. Manual Tests
> 2.1 Test GUIs
> Is this really the only manual test we have?
> We could create checklists of how to test a GUI
> 1. Log in [ ]
> 2. Open Gui [ ]
> 3. perform operation X [ ]
> Z. log out
> These checklists could be the basis of an automated test. Because
> really, we would like to do as little as possible manually.
> I am just floating ideas here, if someone as comments, please add them.
> Regards,
> Karim
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
FOSSGIS Konferenz 2010
2. - 5. März 2010 in Osnabrück
http://www.fossgis.de/konferenz
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
