[Mapbender-dev] too much recursion in savewmc
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Fri Jan 22 10:47:02 EST 2010
The problem exists because we added the attribute options.$target for
each element. This is a jQuery collection of all target DOM elements of
a module. This is very useful for iterating over all target objects.
The downside is, that the map objects are serialized in savewmc. As DOM
elements also point to parents, and parents point back to their
children, a recursion happens. We can no longer serialize the map
objects the we we used to. I will add a toJSON or export method to the
map objects later.
Thanks for pointing this out
Christoph
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
