[Mapbender-dev] Question about legend positioning
Christoph Baudson (Wheregroup)
christoph.baudson at wheregroup.com
Thu Jan 21 13:43:43 EST 2010
Hello,
I wondered why these values are used in mod_legend.php
mod_legend_offsetLeft;
mod_legend_offsetTop;
Apparently these are not element vars, however they are used to move the
legend away from it's original style given in the "Edit application
settings" interface.
I can see the point if stickylegend is true, but why are they also added
when stickylegend is false?
If there is no reason for these adjustments, I will remove two lines
from the source code.
Thanks
Christoph
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
