[Mapbender-dev] Cleaning up
Astrid Emde astrid.emde at wheregroup.com
Wed Jan 20 11:20:34 EST 2010
On Wed, January 20, 2010 12:41 pm, Christoph Baudson (Wheregroup) wrote:
> I'm in the process of cleaning up the http directory. I plan to move the
> refactored files to the plugins folder. These are the modules which are
> included as jQuery plugins and automatically make use of the API.
> I will inquire about certain files at random. Please let me know if you
> need this file
> mod_changeEPSG_dynamic.php
+1
You can delete the file
it never got into action. The functionality is now provided with the new
EPSG-module for project p.
We can add the module to Category:Deprecated
http://www.mapbender.org/ChangeEpsg_dynamic
Best regards
Astrid
> I assume it is deprecated and will delete it unless someone stops me.
> Christoph
> Aufwind durch Wissen!
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu
> _______________________________________
> W h e r e G r o u p GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 15
> Fax: +49 (0)228 / 90 90 38 - 11
> christoph.baudson at wheregroup.com www.wheregroup.com Amtsgericht Bonn, HRA
> 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch: Olaf Knopp, Peter Stamm
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
vertreten durch:
More information about the Mapbender_dev mailing list
