[Mapbender_dev] Admins: [Fwd: Re: [SAC] Projects VM and WebExtra
migration]
Seven (aka Arnulf)
seven at arnulf.us
Thu Jul 1 03:17:54 EDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Michael,
can you please retry using this server:
ssh [yourname]@projects.osgeo.osuosl.org
It works for me and Uli and a few others, so there should be no
difference to your account.
We do not have sudo powers. I will write an email to SAC explaining what
we need and then see how they plan to get this organized.
Best regards,
Arnulf.
Michael Schulz wrote:
> Hi,
> nope, can't login in with my osgeo account (that works with osgeo svn
> and osgeo site).
> Cheers, Michael
> 2010/6/21 Uli Rothstein (WhereGroup) <uli.rothstein at wheregroup.com>:
>> Hey,
>> login is fine but the sudo is not working....
>> Uli
>> Christoph Baudson (Wheregroup) schrieb:
>>> Works for me...
>>> but is mapbender.telascience.org dead? See
>>> http://trac.osgeo.org/osgeo/ticket/595
>>> Confused,
>>> Christoph
>>> Astrid Emde wrote:
>>>> Hello admins,
>>>> I managed to login on the new VM with my OSGeo account.
>>>> Astrid
>>>> On Thu, June 17, 2010 6:01 pm, Seven (aka Arnulf) wrote:
>>> Admins,
>>> the Projects VM is now "almost" in place. Chris tries to do something to
>>> the sudoers file to make maintenance easier for project folks.
>>> Please try to log in with your OSGeo account for a start. It worked for
>>> me.
>>> I have no idea how that machine will survive the onslaught of 16 eager
>>> FOSS4G projects but we will see and learn... :-)
>>> Meanwhile we need to find out which folder to put in our eggs and hatch
>>> them.
>>> Best regards,
>>> Arnulf
>>> -------- Original Message --------
>>> Subject: Re: [SAC] Projects VM and WebExtra migration
>>> Date: Wed, 16 Jun 2010 17:49:26 +0200
>>> From: <christopher.schmidt at nokia.com>
>>> Reply-To: System Administration Committee Discussion/OSGeo
>>> <sac at lists.osgeo.org>
>>> To: <sac at lists.osgeo.org>
>>> References:
>>> <AANLkTin-3WlFS7-KZO9xLZ06vKhd-h-DBTZwx7OewaO9 at mail.gmail.com>
>>> On Jun 16, 2010, at 11:37 AM, ext Frank Warmerdam wrote:
>>>>>>> Folks,
>>>>>>> As discussed at our meeting, the WebExtra VM has
>>>>>>> been moved from osgeo4 to osgeo3 by Lance at OSU OSL. He mentions that
>>>>>>> the system usage looks like this:
>>>>>>> Node DTotal DFree MTotal MNode MFree Pinst Sinst
>>>>>>> osgeo3.osuosl.bak 671.0G 468.7G 47.3G 30.3G 31.0G 6 0
>>>>>>> osgeo4.osuosl.bak 1.1T 283.6G 47.3G 26.2G 34.3G 3 2
>>>>>>> Lance has also created the projects VM as discussed, and
>>>>>>> I have configured it to use the telascience shell authentication
>>>>>>> group. So anyone with login access on the telascience xblades will
>>>>>>> also
>>>>>>> now have access on the projects VM. But currently the sudoer's list is
>>>>>>> still the standard set of SAC VMs. As needed folks will need to ask an
>>>>>>> existing sudoer to add them to the sudoers list on the VM.
>>> I would like to try to make it so that people don't need to be
>>> sudoers for most everyday tasks. I am currently working on setting up
>>> the
>>> VM for projects to migrate to in a sane way without needing
>>> to have sudo access for every task. As a result, I'd like for
>>> projects to
>>> hold off on migrating to the projects VM until after this weekend, if
>>> possible; if I don't get stuff done, we can go ahead and work without
>>> this, but I'd like to take a crack at this first.
>>> -- Chris
>>>>>>> The VM can be reached as:
>>>>>>> I shall endevour to write up some information in the wiki
>>>>>>> about the VM, and perhaps establishing some advice about "good
>>>>>>> behavior"
>>>>>>> on the VM since many projects will be cohabitating there.
>>>>>>> Best regards,
>>>>>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>>>>>> warmerdam at pobox.com light and sound - activate the windows |
>>>>>>> http://pobox.com/~warmerdam
>>>>>>> and watch the world go round - Rush | Geospatial Programmer for Rent
>>>>>>> _______________________________________________
>>>>>>> Sac mailing list
>>>>>>> Sac at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/sac
>>> Regards,
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>> Ulrich Rothstein
>> WhereGroup GmbH & Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Fon: +49 (0)228 / 90 90 38 - 17
>> Fax: +49 (0)228 / 90 90 38 - 11
>> mailto:uli.rothstein at wheregroup.com
>> www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
Arnulf Christl
Exploring Space, Time and Mind
http://arnulf.us
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkwsQSIACgkQXmFKW+BJ1b16EgCeL3ScSqdpArODxd50swVvLgNB
z9wAoIBtVdqyhfWILZM85WzsqJj2EJNf
=Yao9
-----END PGP SIGNATURE-----
More information about the Mapbender_dev
