[Mapbender_dev] Admins: [Fwd: Re: [SAC] Projects VM and WebExtra
migration]
Michael Schulz
mschulz at webgis.de
Thu Jul 1 03:34:56 EDT 2010
Hi Arnulf,
no luck, just tried again, same problem. Permission denied ...
Cheers, Michael
2010/7/1 Seven (aka Arnulf) <seven at arnulf.us>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Michael,
> can you please retry using this server:
> ssh [yourname]@projects.osgeo.osuosl.org
> It works for me and Uli and a few others, so there should be no
> difference to your account.
> We do not have sudo powers. I will write an email to SAC explaining what
> we need and then see how they plan to get this organized.
> Best regards,
> Arnulf.
> Michael Schulz wrote:
>> Hi,
>> nope, can't login in with my osgeo account (that works with osgeo svn
>> and osgeo site).
>> Cheers, Michael
>> 2010/6/21 Uli Rothstein (WhereGroup) <uli.rothstein at wheregroup.com>:
>>> Hey,
>>> login is fine but the sudo is not working....
>>> Uli
>>> Christoph Baudson (Wheregroup) schrieb:
>>>> Works for me...
>>>> but is mapbender.telascience.org dead? See
>>>> http://trac.osgeo.org/osgeo/ticket/595
>>>> Confused,
>>>> Christoph
>>>> Astrid Emde wrote:
>>>>> Hello admins,
>>>>> I managed to login on the new VM with my OSGeo account.
>>>>> Astrid
>>>>> On Thu, June 17, 2010 6:01 pm, Seven (aka Arnulf) wrote:
>>>> Admins,
>>>> the Projects VM is now "almost" in place. Chris tries to do something to
>>>> the sudoers file to make maintenance easier for project folks.
>>>> Please try to log in with your OSGeo account for a start. It worked for
>>>> me.
>>>> I have no idea how that machine will survive the onslaught of 16 eager
>>>> FOSS4G projects but we will see and learn... :-)
>>>> Meanwhile we need to find out which folder to put in our eggs and hatch
>>>> them.
>>>> Best regards,
>>>> Arnulf
>>>> -------- Original Message --------
>>>> Subject: Re: [SAC] Projects VM and WebExtra migration
>>>> Date: Wed, 16 Jun 2010 17:49:26 +0200
>>>> From: <christopher.schmidt at nokia.com>
>>>> Reply-To: System Administration Committee Discussion/OSGeo
>>>> <sac at lists.osgeo.org>
>>>> To: <sac at lists.osgeo.org>
>>>> References:
>>>> <AANLkTin-3WlFS7-KZO9xLZ06vKhd-h-DBTZwx7OewaO9 at mail.gmail.com>
>>>> On Jun 16, 2010, at 11:37 AM, ext Frank Warmerdam wrote:
>>>>>>>> Folks,
>>>>>>>> As discussed at our meeting, the WebExtra VM has
>>>>>>>> been moved from osgeo4 to osgeo3 by Lance at OSU OSL. He mentions that
>>>>>>>> the system usage looks like this:
>>>>>>>> Node DTotal DFree MTotal MNode MFree Pinst Sinst
>>>>>>>> osgeo3.osuosl.bak 671.0G 468.7G 47.3G 30.3G 31.0G 6 0
>>>>>>>> osgeo4.osuosl.bak 1.1T 283.6G 47.3G 26.2G 34.3G 3 2
>>>>>>>> Lance has also created the projects VM as discussed, and
>>>>>>>> I have configured it to use the telascience shell authentication
>>>>>>>> group. So anyone with login access on the telascience xblades will
>>>>>>>> also
>>>>>>>> now have access on the projects VM. But currently the sudoer's list is
>>>>>>>> still the standard set of SAC VMs. As needed folks will need to ask an
>>>>>>>> existing sudoer to add them to the sudoers list on the VM.
>>>> I would like to try to make it so that people don't need to be
>>>> sudoers for most everyday tasks. I am currently working on setting up
>>>> the
>>>> VM for projects to migrate to in a sane way without needing
>>>> to have sudo access for every task. As a result, I'd like for
>>>> projects to
>>>> hold off on migrating to the projects VM until after this weekend, if
>>>> possible; if I don't get stuff done, we can go ahead and work without
>>>> this, but I'd like to take a crack at this first.
>>>> -- Chris
>>>>>>>> The VM can be reached as:
>>>>>>>> I shall endevour to write up some information in the wiki
>>>>>>>> about the VM, and perhaps establishing some advice about "good
>>>>>>>> behavior"
>>>>>>>> on the VM since many projects will be cohabitating there.
>>>>>>>> Best regards,
>>>>>>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>>>>>>> warmerdam at pobox.com light and sound - activate the windows |
>>>>>>>> http://pobox.com/~warmerdam
>>>>>>>> and watch the world go round - Rush | Geospatial Programmer for Rent
>>>>>>>> _______________________________________________
>>>>>>>> Sac mailing list
>>>>>>>> Sac at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/sac
>>>> Regards,
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>>> Ulrich Rothstein
>>> WhereGroup GmbH & Co. KG
>>> Siemensstraße 8
>>> 53121 Bonn
>>> Germany
>>> Fon: +49 (0)228 / 90 90 38 - 17
>>> Fax: +49 (0)228 / 90 90 38 - 11
>>> mailto:uli.rothstein at wheregroup.com
>>> www.wheregroup.com
>>> Amtsgericht Bonn, HRA 6788
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Olaf Knopp, Peter Stamm
> Arnulf Christl
> Exploring Space, Time and Mind
> http://arnulf.us
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAkwsQSIACgkQXmFKW+BJ1b16EgCeL3ScSqdpArODxd50swVvLgNB
> z9wAoIBtVdqyhfWILZM85WzsqJj2EJNf
> =Yao9
> -----END PGP SIGNATURE-----
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-academy.eu/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100 Freiburg i. Br.
Tel: +49 (0)761 705798-102
Tel: +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_dev
