[Mapbender_dev] Admins: [Fwd: Re: [SAC] Projects VM and WebExtra
migration]
Seven (aka Arnulf)
seven at arnulf.us
Thu Jul 1 03:43:24 EDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Michael Schulz wrote:
> Hi Arnulf,
> no luck, just tried again, same problem. Permission denied ...
> Cheers, Michael
Can you please file a ticket?
Christoph,
I just closed your ticket with a "worksforme". Can you please also retry
and reopen if it still gives you the error?
http://trac.osgeo.org/osgeo/ticket/595
Thanks, Arnulf
> 2010/7/1 Seven (aka Arnulf) <seven at arnulf.us>:
> Michael,
> can you please retry using this server:
> ssh [yourname]@projects.osgeo.osuosl.org
> It works for me and Uli and a few others, so there should be no
> difference to your account.
> We do not have sudo powers. I will write an email to SAC explaining what
> we need and then see how they plan to get this organized.
> Best regards,
> Arnulf.
>>>> Hi,
>>>> nope, can't login in with my osgeo account (that works with osgeo svn
>>>> and osgeo site).
>>>> Cheers, Michael
>>>> 2010/6/21 Uli Rothstein (WhereGroup) <uli.rothstein at wheregroup.com>:
>>>>> Hey,
>>>>> login is fine but the sudo is not working....
>>>>> Uli
>>>>> Christoph Baudson (Wheregroup) schrieb:
>>>>>> Works for me...
>>>>>> but is mapbender.telascience.org dead? See
>>>>>> Confused,
>>>>>> Christoph
>>>>>> Astrid Emde wrote:
>>>>>>> Hello admins,
>>>>>>> I managed to login on the new VM with my OSGeo account.
>>>>>>> Astrid
>>>>>>> On Thu, June 17, 2010 6:01 pm, Seven (aka Arnulf) wrote:
>>>>>> Admins,
>>>>>> the Projects VM is now "almost" in place. Chris tries to do something to
>>>>>> the sudoers file to make maintenance easier for project folks.
>>>>>> Please try to log in with your OSGeo account for a start. It worked for
>>>>>> me.
>>>>>> I have no idea how that machine will survive the onslaught of 16 eager
>>>>>> FOSS4G projects but we will see and learn... :-)
>>>>>> Meanwhile we need to find out which folder to put in our eggs and hatch
>>>>>> them.
>>>>>> Best regards,
>>>>>> Arnulf
>>>>>> -------- Original Message --------
>>>>>> Subject: Re: [SAC] Projects VM and WebExtra migration
>>>>>> Date: Wed, 16 Jun 2010 17:49:26 +0200
>>>>>> From: <christopher.schmidt at nokia.com>
>>>>>> Reply-To: System Administration Committee Discussion/OSGeo
>>>>>> <sac at lists.osgeo.org>
>>>>>> To: <sac at lists.osgeo.org>
>>>>>> References:
>>>>>> <AANLkTin-3WlFS7-KZO9xLZ06vKhd-h-DBTZwx7OewaO9 at mail.gmail.com>
>>>>>> On Jun 16, 2010, at 11:37 AM, ext Frank Warmerdam wrote:
>>>>>>>>>> Folks,
>>>>>>>>>> As discussed at our meeting, the WebExtra VM has
>>>>>>>>>> been moved from osgeo4 to osgeo3 by Lance at OSU OSL. He mentions that
>>>>>>>>>> the system usage looks like this:
>>>>>>>>>> Node DTotal DFree MTotal MNode MFree Pinst Sinst
>>>>>>>>>> osgeo3.osuosl.bak 671.0G 468.7G 47.3G 30.3G 31.0G 6 0
>>>>>>>>>> osgeo4.osuosl.bak 1.1T 283.6G 47.3G 26.2G 34.3G 3 2
>>>>>>>>>> Lance has also created the projects VM as discussed, and
>>>>>>>>>> I have configured it to use the telascience shell authentication
>>>>>>>>>> group. So anyone with login access on the telascience xblades will
>>>>>>>>>> also
>>>>>>>>>> now have access on the projects VM. But currently the sudoer's list is
>>>>>>>>>> still the standard set of SAC VMs. As needed folks will need to ask an
>>>>>>>>>> existing sudoer to add them to the sudoers list on the VM.
>>>>>> I would like to try to make it so that people don't need to be
>>>>>> sudoers for most everyday tasks. I am currently working on setting up
>>>>>> the
>>>>>> VM for projects to migrate to in a sane way without needing
>>>>>> to have sudo access for every task. As a result, I'd like for
>>>>>> projects to
>>>>>> hold off on migrating to the projects VM until after this weekend, if
>>>>>> possible; if I don't get stuff done, we can go ahead and work without
>>>>>> this, but I'd like to take a crack at this first.
>>>>>> -- Chris
>>>>>>>>>> The VM can be reached as:
>>>>>>>>>> I shall endevour to write up some information in the wiki
>>>>>>>>>> about the VM, and perhaps establishing some advice about "good
>>>>>>>>>> behavior"
>>>>>>>>>> on the VM since many projects will be cohabitating there.
>>>>>>>>>> Best regards,
>>>>>>>>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>>>>>>>>> warmerdam at pobox.com light and sound - activate the windows |
>>>>>>>>>> http://pobox.com/~warmerdam
>>>>>>>>>> and watch the world go round - Rush | Geospatial Programmer for Rent
>>>>>>>>>> _______________________________________________
>>>>>>>>>> Sac mailing list
>>>>>>>>>> Sac at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/sac
>>>>>> Regards,
>>>>> Mapbender_dev mailing list
>>>>> Mapbender_dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>>>>> Ulrich Rothstein
>>>>> WhereGroup GmbH & Co. KG
>>>>> Siemensstraße 8
>>>>> 53121 Bonn
>>>>> Germany
>>>>> Fon: +49 (0)228 / 90 90 38 - 17
>>>>> Fax: +49 (0)228 / 90 90 38 - 11
>>>>> mailto:uli.rothstein at wheregroup.com
>>>>> www.wheregroup.com
>>>>> Amtsgericht Bonn, HRA 6788
>>>>> Komplementärin:
>>>>> WhereGroup Verwaltungs GmbH
>>>>> vertreten durch:
>>>>> Olaf Knopp, Peter Stamm
Arnulf Christl
Exploring Space, Time and Mind
http://arnulf.us
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkwsRxwACgkQXmFKW+BJ1b2QrgCfdcFAA1NyQn4R/wyOdPIirIY0
mUUAnRw0HCsaz7rA39PdxMf4gM8qZ/Y3
=KSt9
-----END PGP SIGNATURE-----
More information about the Mapbender_dev
