[Mapbender_dev] Admins: [Fwd: Re: [SAC] Projects VM and WebExtra migration]
Michael Schulz mschulz at webgis.de
Tue Jul 6 10:24:23 EDT 2010
Hey folks,
login on projects vm is now working, thanks to FrankW. Here's the explanation:
---- snip
#600: projects vm: osgeo ldap login not working?
 Reporter:  mschulz                           |        Owner:  sac@…
    Type:  defect                            |       Status:  closed
 Priority:  normal                            |    Milestone:
Component:  Systems Admin                     |   Resolution:  fixed
 Keywords:  mapbender, ldap, shell, projects  |
Changes (by warmerdam):
 * keywords:  mapbender => mapbender, ldap, shell, projects
 * status:  new => closed
 * resolution:  => fixed
Comment:
 To get login access to the projects VM and and some other machines it is
 necessary to be a member of the "telescience" LDAP shell group:
  https://www.osgeo.org/cgi-
 bin/auth/ldap_shell.py?new_member=mschulz&group=telascience&ou=Shell
 I have added you.  Any existing member of the group can add new members as
 needed.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/600#comment:1>
---- /snip
Cheers, Michael
2010/7/1 Michael Schulz <mschulz at webgis.de>:
> in the osgeo trac, I assume?
> BTW, I get the same error as Christoph when ssh'ing mapbender.telascience.org
> Michael
> 2010/7/1 Seven (aka Arnulf) <seven at arnulf.us>:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Michael Schulz wrote:
>>> Hi Arnulf,
>>> no luck, just tried again, same problem. Permission denied ...
>>> Cheers, Michael
>> Can you please file a ticket?
>> Christoph,
>> I just closed your ticket with a "worksforme". Can you please also retry
>> and reopen if it still gives you the error?
>> http://trac.osgeo.org/osgeo/ticket/595
>> Thanks, Arnulf
>>> Michael,
>>> can you please retry using this server:
>>> ssh [yourname]@projects.osgeo.osuosl.org
>>> It works for me and Uli and a few others, so there should be no
>>> difference to your account.
>>> We do not have sudo powers. I will write an email to SAC explaining what
>>> we need and then see how they plan to get this organized.
>>> Best regards,
>>> Arnulf.
>>>>>> Hi,
>>>>>> nope, can't login in with my osgeo account (that works with osgeo svn
>>>>>> and osgeo site).
>>>>>> Cheers, Michael
>>>>>> 2010/6/21 Uli Rothstein (WhereGroup) <uli.rothstein at wheregroup.com>:
>>>>>>> Hey,
>>>>>>> login is fine but the sudo is not working....
>>>>>>> Uli
>>>>>>> Christoph Baudson (Wheregroup) schrieb:
>>>>>>>> Works for me...
>>>>>>>> but is mapbender.telascience.org dead? See
>>>>>>>> Confused,
>>>>>>>> Christoph
>>>>>>>> Astrid Emde wrote:
>>>>>>>>> Hello admins,
>>>>>>>>> I managed to login on the new VM with my OSGeo account.
>>>>>>>>> Astrid
>>>>>>>>> On Thu, June 17, 2010 6:01 pm, Seven (aka Arnulf) wrote:
>>>>>>>> Admins,
>>>>>>>> the Projects VM is now "almost" in place. Chris tries to do something to
>>>>>>>> the sudoers file to make maintenance easier for project folks.
>>>>>>>> Please try to log in with your OSGeo account for a start. It worked for
>>>>>>>> me.
>>>>>>>> I have no idea how that machine will survive the onslaught of 16 eager
>>>>>>>> FOSS4G projects but we will see and learn... :-)
>>>>>>>> Meanwhile we need to find out which folder to put in our eggs and hatch
>>>>>>>> them.
>>>>>>>> Best regards,
>>>>>>>> Arnulf
>>>>>>>> -------- Original Message --------
>>>>>>>> Subject: Re: [SAC] Projects VM and WebExtra migration
>>>>>>>> Date: Wed, 16 Jun 2010 17:49:26 +0200
>>>>>>>> From: <christopher.schmidt at nokia.com>
>>>>>>>> Reply-To: System Administration Committee Discussion/OSGeo
>>>>>>>> <sac at lists.osgeo.org>
>>>>>>>> To: <sac at lists.osgeo.org>
>>>>>>>> References:
>>>>>>>> <AANLkTin-3WlFS7-KZO9xLZ06vKhd-h-DBTZwx7OewaO9 at mail.gmail.com>
>>>>>>>> On Jun 16, 2010, at 11:37 AM, ext Frank Warmerdam wrote:
>>>>>>>>>>>> Folks,
>>>>>>>>>>>> As discussed at our meeting, the WebExtra VM has
>>>>>>>>>>>> been moved from osgeo4 to osgeo3 by Lance at OSU OSL. He mentions that
>>>>>>>>>>>> the system usage looks like this:
>>>>>>>>>>>> Node              DTotal  DFree MTotal MNode MFree Pinst Sinst
>>>>>>>>>>>> osgeo3.osuosl.bak 671.0G 468.7G  47.3G 30.3G 31.0G     6     0
>>>>>>>>>>>> osgeo4.osuosl.bak   1.1T 283.6G  47.3G 26.2G 34.3G     3     2
>>>>>>>>>>>> Lance has also created the projects VM as discussed, and
>>>>>>>>>>>> I have configured it to use the telascience shell authentication
>>>>>>>>>>>> group.  So anyone with login access on the telascience xblades will
>>>>>>>>>>>> also
>>>>>>>>>>>> now have access on the projects VM. But currently the sudoer's list is
>>>>>>>>>>>> still the standard set of SAC VMs.  As needed folks will need to ask an
>>>>>>>>>>>> existing sudoer to add them to the sudoers list on the VM.
>>>>>>>> I would like to try to make it so that people don't need to be
>>>>>>>> sudoers for most everyday tasks. I am currently working on setting up
>>>>>>>> the
>>>>>>>> VM for projects to migrate to in a sane way without needing
>>>>>>>> to have sudo access for every task. As a result, I'd like for
>>>>>>>> projects to
>>>>>>>> hold off on migrating to the projects VM until after this weekend, if
>>>>>>>> possible; if I don't get stuff done, we can go ahead and work without
>>>>>>>> this, but I'd like to take a crack at this first.
>>>>>>>> -- Chris
>>>>>>>>>>>> The VM can be reached as:
>>>>>>>>>>>> I shall endevour to write up some information in the wiki
>>>>>>>>>>>> about the VM, and perhaps establishing some advice about "good
>>>>>>>>>>>> behavior"
>>>>>>>>>>>> on the VM since many projects will be cohabitating there.
>>>>>>>>>>>> Best regards,
>>>>>>>>>>>> I set the clouds in motion - turn up   | Frank Warmerdam,
>>>>>>>>>>>> warmerdam at pobox.com light and sound - activate the windows |
>>>>>>>>>>>> http://pobox.com/~warmerdam
>>>>>>>>>>>> and watch the world go round - Rush    | Geospatial Programmer for Rent
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> Sac mailing list
>>>>>>>>>>>> Sac at lists.osgeo.org
>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/sac
>>>>>>>> Regards,
>>>>>>> Mapbender_dev mailing list
>>>>>>> Mapbender_dev at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>>>>>>> Ulrich Rothstein
>>>>>>> WhereGroup GmbH & Co. KG
>>>>>>> Siemensstraße 8
>>>>>>> 53121 Bonn
>>>>>>> Germany
>>>>>>> Fon: +49 (0)228 / 90 90 38 - 17
>>>>>>> Fax: +49 (0)228 / 90 90 38 - 11
>>>>>>> mailto:uli.rothstein at wheregroup.com
>>>>>>> www.wheregroup.com
>>>>>>> Amtsgericht Bonn, HRA 6788
>>>>>>> Komplementärin:
>>>>>>> WhereGroup Verwaltungs GmbH
>>>>>>> vertreten durch:
>>>>>>> Olaf Knopp, Peter Stamm
>> Arnulf Christl
>> Exploring Space, Time and Mind
>> http://arnulf.us
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.9 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>> iEYEARECAAYFAkwsRxwACgkQXmFKW+BJ1b2QrgCfdcFAA1NyQn4R/wyOdPIirIY0
>> mUUAnRw0HCsaz7rA39PdxMf4gM8qZ/Y3
>> =KSt9
>> -----END PGP SIGNATURE-----
> Aufwind durch Wissen!
> Qualifizierte Open Source Schulungen bei der
> http://www.foss-academy.eu/
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> Schwimmbadstraße 2
> D-79100  Freiburg i. Br.
> Tel:  +49 (0)761 705798-102
> Tel:  +49 (0)761 705798-0
> Fax: +49 (0)761 705798-09
> http://www.webgis.de / http://www.zopecms.de
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Michael Schulz
in medias res
Schwimmbadstraße 2
More information about the Mapbender_dev mailing list
