[Mapbender_dev] mental notes on installation shell script
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Wed Jul 21 11:04:07 EDT 2010
Hello developers,
here are some mental notes on the installation script
(resources/db/install.sh). we could
- copy mapbender.conf-dist to mapbender.conf
- add database information to mapbender.conf (via sed). The values are
already being read from command line
- concatenate all relevant SQLs into one temporary file via cat (the
password is only requested once if a single file is executed, and not n
times)
I'm not sure how this would work under Windows.
These additions might seem trivial, but would make an installation even
less work.
Christoph
FOSS4G 2010
06.-09. September 2010 in Barcelona
http://2010.foss4g.org
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
