[Mapbender_dev] Admins: [Fwd: Re: [SAC] Projects VM and WebExtra
	migration]
    Seven (aka Arnulf)
    seven at arnulf.us
    Thu Jun 17 14:01:37 EDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Admins,
the Projects VM is now "almost" in place. Chris tries to do something to
the sudoers file to make maintenance easier for project folks.
Please try to log in with your OSGeo account for a start. It worked for me.
I have no idea how that machine will survive the onslaught of 16 eager
FOSS4G projects but we will see and learn... :-)
Meanwhile we need to find out which folder to put in our eggs and hatch
them.
Best regards,
Arnulf
- -------- Original Message --------
Subject: Re: [SAC] Projects VM and WebExtra migration
Date: Wed, 16 Jun 2010 17:49:26 +0200
Reply-To: System Administration Committee Discussion/OSGeo
<sac at lists.osgeo.org>
To: <sac at lists.osgeo.org>
References: <AANLkTin-3WlFS7-KZO9xLZ06vKhd-h-DBTZwx7OewaO9 at mail.gmail.com>
On Jun 16, 2010, at 11:37 AM, ext Frank Warmerdam wrote:
> Folks,
> As discussed at our meeting, the WebExtra VM has
> been moved from osgeo4 to osgeo3 by Lance at OSU OSL.
> He mentions that the system usage looks like this:
> Node              DTotal  DFree MTotal MNode MFree Pinst Sinst
> osgeo3.osuosl.bak 671.0G 468.7G  47.3G 30.3G 31.0G     6     0
> osgeo4.osuosl.bak   1.1T 283.6G  47.3G 26.2G 34.3G     3     2
> Lance has also created the projects VM as discussed, and
> I have configured it to use the telascience shell authentication
> group.  So anyone with login access on the telascience
> xblades will also now have access on the projects VM.
> But currently the sudoer's list is still the standard set of
> SAC VMs.  As needed folks will need to ask an existing
> sudoer to add them to the sudoers list on the VM.
I would like to try to make it so that people don't need to be
sudoers for most everyday tasks. I am currently working on setting
up the VM for projects to migrate to in a sane way without needing
to have sudo access for every task. As a result, I'd like for
projects to hold off on migrating to the projects VM until
after this weekend, if possible; if I don't get stuff done,
we can go ahead and work without this, but I'd like to take a
crack at this first.
- -- Chris
> The VM can be reached as:
>  projects.osgeo.osuosl.org
> I shall endevour to write up some information in the wiki
> about the VM, and perhaps establishing some advice
> about "good behavior" on the VM since many projects
> will be cohabitating there.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Sac mailing list
> Sac at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/sac
Regards,
Christopher Schmidt
Nokia
Sac mailing list
Arnulf Christl
Exploring Space, Time and Mind
http://arnulf.us
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkwaYwEACgkQXmFKW+BJ1b2fDQCeOa7AUVFzAnaKa6yq1buqwHnF
814An10u45q14PdWjqld5/rTHFLRe9qu
=SaX4
-----END PGP SIGNATURE-----
More information about the Mapbender_dev
