[Mapbender_dev] Admins: [Fwd: Re: [SAC] Projects VM and WebExtra migration]
Astrid Emde astrid.emde at wheregroup.com
Mon Jun 21 00:58:38 EDT 2010
Hello admins,
I managed to login on the new VM with my OSGeo account.
Astrid
On Thu, June 17, 2010 6:01 pm, Seven (aka Arnulf) wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Admins,
> the Projects VM is now "almost" in place. Chris tries to do something to
> the sudoers file to make maintenance easier for project folks.
> Please try to log in with your OSGeo account for a start. It worked for
> me.
> I have no idea how that machine will survive the onslaught of 16 eager
> FOSS4G projects but we will see and learn... :-)
> Meanwhile we need to find out which folder to put in our eggs and hatch
> them.
> Best regards,
> Arnulf
> - -------- Original Message --------
> Subject: Re: [SAC] Projects VM and WebExtra migration
> Date: Wed, 16 Jun 2010 17:49:26 +0200
> From: <christopher.schmidt at nokia.com>
> Reply-To: System Administration Committee Discussion/OSGeo
> <sac at lists.osgeo.org>
> To: <sac at lists.osgeo.org>
> References: <AANLkTin-3WlFS7-KZO9xLZ06vKhd-h-DBTZwx7OewaO9 at mail.gmail.com>
> On Jun 16, 2010, at 11:37 AM, ext Frank Warmerdam wrote:
>> Folks,
>> As discussed at our meeting, the WebExtra VM has
>> been moved from osgeo4 to osgeo3 by Lance at OSU OSL. He mentions that
>> the system usage looks like this:
>> Node              DTotal  DFree MTotal MNode MFree Pinst Sinst
>> osgeo3.osuosl.bak 671.0G 468.7G  47.3G 30.3G 31.0G     6     0
>> osgeo4.osuosl.bak   1.1T 283.6G  47.3G 26.2G 34.3G     3     2
>> Lance has also created the projects VM as discussed, and
>> I have configured it to use the telascience shell authentication
>> group.  So anyone with login access on the telascience xblades will also
>> now have access on the projects VM. But currently the sudoer's list is
>> still the standard set of SAC VMs.  As needed folks will need to ask an
>> existing sudoer to add them to the sudoers list on the VM.
> I would like to try to make it so that people don't need to be
> sudoers for most everyday tasks. I am currently working on setting up the
> VM for projects to migrate to in a sane way without needing
> to have sudo access for every task. As a result, I'd like for projects to
> hold off on migrating to the projects VM until after this weekend, if
> possible; if I don't get stuff done, we can go ahead and work without
> this, but I'd like to take a crack at this first.
> - -- Chris
>> The VM can be reached as:
>> projects.osgeo.osuosl.org
>> I shall endevour to write up some information in the wiki
>> about the VM, and perhaps establishing some advice about "good behavior"
>> on the VM since many projects will be cohabitating there.
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam,
>> warmerdam at pobox.com light and sound - activate the windows |
>> http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | Geospatial Programmer for Rent
>> Sac mailing list
>> Sac at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/sac
> Regards,
> Christopher Schmidt
> Nokia
> Sac mailing list
> Arnulf Christl
> Exploring Space, Time and Mind
> http://arnulf.us
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAkwaYwEACgkQXmFKW+BJ1b2fDQCeOa7AUVFzAnaKa6yq1buqwHnF
> 814An10u45q14PdWjqld5/rTHFLRe9qu
> =SaX4
> -----END PGP SIGNATURE-----
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
AGIT 2010
7.-9. Juli 2010 in Salzburg
Treffen Sie die WhereGroup an Stand Nr. 30
http://www.agit.at
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
