[Mapbender_dev] Admins: [Fwd: Re: [SAC] Projects VM and
WebExtra migration]
Christoph Baudson (Wheregroup)
christoph.baudson at wheregroup.com
Mon Jun 21 12:24:32 EDT 2010
Works for me...
but is mapbender.telascience.org dead? See
http://trac.osgeo.org/osgeo/ticket/595
Confused,
Christoph
Astrid Emde wrote:
> Hello admins,
> I managed to login on the new VM with my OSGeo account.
> Astrid
> On Thu, June 17, 2010 6:01 pm, Seven (aka Arnulf) wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Admins,
>> the Projects VM is now "almost" in place. Chris tries to do something to
>> the sudoers file to make maintenance easier for project folks.
>> Please try to log in with your OSGeo account for a start. It worked for
>> me.
>> I have no idea how that machine will survive the onslaught of 16 eager
>> FOSS4G projects but we will see and learn... :-)
>> Meanwhile we need to find out which folder to put in our eggs and hatch
>> them.
>> Best regards,
>> Arnulf
>> - -------- Original Message --------
>> Subject: Re: [SAC] Projects VM and WebExtra migration
>> Date: Wed, 16 Jun 2010 17:49:26 +0200
>> From: <christopher.schmidt at nokia.com>
>> Reply-To: System Administration Committee Discussion/OSGeo
>> <sac at lists.osgeo.org>
>> To: <sac at lists.osgeo.org>
>> References: <AANLkTin-3WlFS7-KZO9xLZ06vKhd-h-DBTZwx7OewaO9 at mail.gmail.com>
>> On Jun 16, 2010, at 11:37 AM, ext Frank Warmerdam wrote:
>>> Folks,
>>> As discussed at our meeting, the WebExtra VM has
>>> been moved from osgeo4 to osgeo3 by Lance at OSU OSL. He mentions that
>>> the system usage looks like this:
>>> Node DTotal DFree MTotal MNode MFree Pinst Sinst
>>> osgeo3.osuosl.bak 671.0G 468.7G 47.3G 30.3G 31.0G 6 0
>>> osgeo4.osuosl.bak 1.1T 283.6G 47.3G 26.2G 34.3G 3 2
>>> Lance has also created the projects VM as discussed, and
>>> I have configured it to use the telascience shell authentication
>>> group. So anyone with login access on the telascience xblades will also
>>> now have access on the projects VM. But currently the sudoer's list is
>>> still the standard set of SAC VMs. As needed folks will need to ask an
>>> existing sudoer to add them to the sudoers list on the VM.
>> I would like to try to make it so that people don't need to be
>> sudoers for most everyday tasks. I am currently working on setting up the
>> VM for projects to migrate to in a sane way without needing
>> to have sudo access for every task. As a result, I'd like for projects to
>> hold off on migrating to the projects VM until after this weekend, if
>> possible; if I don't get stuff done, we can go ahead and work without
>> this, but I'd like to take a crack at this first.
>> - -- Chris
>>> The VM can be reached as:
>>> projects.osgeo.osuosl.org
>>> I shall endevour to write up some information in the wiki
>>> about the VM, and perhaps establishing some advice about "good behavior"
>>> on the VM since many projects will be cohabitating there.
>>> Best regards,
>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>> warmerdam at pobox.com light and sound - activate the windows |
>>> http://pobox.com/~warmerdam
>>> and watch the world go round - Rush | Geospatial Programmer for Rent
>>> Sac mailing list
>>> Sac at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/sac
>> Regards,
>> Christopher Schmidt
>> Nokia
>> Sac mailing list
>> Arnulf Christl
>> Exploring Space, Time and Mind
>> http://arnulf.us
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.9 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>> iEYEARECAAYFAkwaYwEACgkQXmFKW+BJ1b2fDQCeOa7AUVFzAnaKa6yq1buqwHnF
>> 814An10u45q14PdWjqld5/rTHFLRe9qu
>> =SaX4
>> -----END PGP SIGNATURE-----
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
AGIT 2010
7.-9. Juli 2010 in Salzburg
Treffen Sie die WhereGroup an Stand Nr. 30
http://www.agit.at
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
