[Mapbender_dev] Admins: [Fwd: Re: [SAC] Projects VM and
WebExtra migration]
Uli Rothstein (WhereGroup)
uli.rothstein at wheregroup.com
Mon Jun 21 12:36:22 EDT 2010
Hey,
login is fine but the sudo is not working....
Uli
Christoph Baudson (Wheregroup) schrieb:
> Works for me...
> but is mapbender.telascience.org dead? See
> http://trac.osgeo.org/osgeo/ticket/595
> Confused,
> Christoph
> Astrid Emde wrote:
>> Hello admins,
>> I managed to login on the new VM with my OSGeo account.
>> Astrid
>> On Thu, June 17, 2010 6:01 pm, Seven (aka Arnulf) wrote:
> Admins,
> the Projects VM is now "almost" in place. Chris tries to do something to
> the sudoers file to make maintenance easier for project folks.
> Please try to log in with your OSGeo account for a start. It worked for
> me.
> I have no idea how that machine will survive the onslaught of 16 eager
> FOSS4G projects but we will see and learn... :-)
> Meanwhile we need to find out which folder to put in our eggs and hatch
> them.
> Best regards,
> Arnulf
> -------- Original Message --------
> Subject: Re: [SAC] Projects VM and WebExtra migration
> Date: Wed, 16 Jun 2010 17:49:26 +0200
> From: <christopher.schmidt at nokia.com>
> Reply-To: System Administration Committee Discussion/OSGeo
> <sac at lists.osgeo.org>
> To: <sac at lists.osgeo.org>
> References:
> <AANLkTin-3WlFS7-KZO9xLZ06vKhd-h-DBTZwx7OewaO9 at mail.gmail.com>
> On Jun 16, 2010, at 11:37 AM, ext Frank Warmerdam wrote:
>>>>> Folks,
>>>>> As discussed at our meeting, the WebExtra VM has
>>>>> been moved from osgeo4 to osgeo3 by Lance at OSU OSL. He mentions that
>>>>> the system usage looks like this:
>>>>> Node DTotal DFree MTotal MNode MFree Pinst Sinst
>>>>> osgeo3.osuosl.bak 671.0G 468.7G 47.3G 30.3G 31.0G 6 0
>>>>> osgeo4.osuosl.bak 1.1T 283.6G 47.3G 26.2G 34.3G 3 2
>>>>> Lance has also created the projects VM as discussed, and
>>>>> I have configured it to use the telascience shell authentication
>>>>> group. So anyone with login access on the telascience xblades will
>>>>> also
>>>>> now have access on the projects VM. But currently the sudoer's list is
>>>>> still the standard set of SAC VMs. As needed folks will need to ask an
>>>>> existing sudoer to add them to the sudoers list on the VM.
> I would like to try to make it so that people don't need to be
> sudoers for most everyday tasks. I am currently working on setting up
> the
> VM for projects to migrate to in a sane way without needing
> to have sudo access for every task. As a result, I'd like for
> projects to
> hold off on migrating to the projects VM until after this weekend, if
> possible; if I don't get stuff done, we can go ahead and work without
> this, but I'd like to take a crack at this first.
> -- Chris
>>>>> The VM can be reached as:
>>>>> projects.osgeo.osuosl.org
>>>>> I shall endevour to write up some information in the wiki
>>>>> about the VM, and perhaps establishing some advice about "good
>>>>> behavior"
>>>>> on the VM since many projects will be cohabitating there.
>>>>> Best regards,
>>>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>>>> warmerdam at pobox.com light and sound - activate the windows |
>>>>> http://pobox.com/~warmerdam
>>>>> and watch the world go round - Rush | Geospatial Programmer for Rent
>>>>> _______________________________________________
>>>>> Sac mailing list
>>>>> Sac at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/sac
> Regards,
Mapbender_dev mailing list
Mapbender_dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Ulrich Rothstein
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:uli.rothstein at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
