[Mapbender_dev] [Mapbender] #651: Problems with digitizing using connectiontype curl
Mapbender mapbender_dev at lists.osgeo.org
Tue Jun 29 06:19:17 EDT 2010
 Reporter:  mschulz  |       Owner:  dev
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  2.6.2 release
Component:  core     |     Version:  2.6
 Keywords:           |
 Digitizing using connectiontype curl may not be working correctly. Not
 sure whether Geoserver (2.0.2) version as wfs-t is relevant. The problem
 is that the post request does not have the xml body set, because in
 class_connector.php:169 httpType is compared to "POST" (uppercase) whereas
 class_ows sets httpType to "post" (lowercase). Thus the request curl
 initiates is not a post but a get request.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/651>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
