[Mapbender_dev] Re: [Mapbender-dev] Slimming down OpenLayers
Christoph Baudson christoph at baudson.de
Tue May 18 05:09:55 EDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Thanks for bringing this us.
you can easily load only the components you need. There are tools like
http://openlayerer.appspot.com/
on the one hand, but Mapbender would do the build itself. You would have
an Openlayers core module, and load everything else you need in
application elements. It would be like a custom build.
I think you can get Openlayers at roughly 100K this way.
Christoph
Seven (aka Arnulf) wrote:
> Folks,
> pertinent to the discussion yesterday about where the project is going
> Christoph again proposed to go for OpenLayers as the (only) viewing
> component to reduce the scope of development. One argument that I always
> bring up against this is that OpenLayers is way too fat. It invariably
> crams several 100k through the pipe and into the browser while all that
> is needed in many cases are just a few 10k. With 2.9 this has not become
> any better. Today I found this blog [1] that describes hwo to reduce the
> size of OpenLayers from a user perspective. If we go for OpenLayers
> could we work backwards by starting with as little OL code as possible
> and increasing as we add functionality? Then we could always trade off
> functionality for weight and balance both as best required by the
> corresponding project.
> Best regards,
> Arnulf.
> [1] http://linfiniti.com/2010/05/slimming-down-openlayers/
Mapbender_dev mailing list
Mapbender_dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_dev
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkvyWV8ACgkQGtMIfbycMX7RUACbBBEIYHf7ks38nnc2+z2myt/X
88QAoIxCO6HrBEx4IttTLkxEIwmTA7GL
=Jb8e
-----END PGP SIGNATURE-----
More information about the Mapbender_dev mailing list
