[Mapbender_dev] EPSG:4326 tend to take random values even though maps are nearly the same
Marc Jansen jansen at terrestris.de
Fri May 21 05:09:39 EDT 2010
Hi Abhishek,
just a quick guessing here, but with a geographic projection like 4326
scale isn't trivial to calculate, as there are AFAICT two scales to be
considered (at the poles the metric distance between lon-values is
zero). With Mercator-based projections both axises share the same scale.
I am always more or less unsure about this stuff, so if the above
contains errors, don't throw stones at me.
Regards,
Marc
On 20.05.2010 10:33, Abhishek Singh wrote:
> Hi,
> I am having some problem with the scales values that appear in case of
> epsg:4326 and epsg:31467 in gui1. I have modified the getScale(), code
> snippet is available at http://osgeo.pastebin.com/U44pVU2v .The
> problem is that even though maps nearly appear to be the same for
> epsg:4326 and epsg:31467, the scale values aren't showing that
> correspondence. The scale values in case of epsg:4326 tend to take
> scale values like 1:14, 1:19 etc.
> please suggest how to remove that error.
> Thanks,
> Abhishek Kumar Singh
> BE/1349/2007
> Information Technology
> 6th SEMESTER
> BIT MESRA
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
    Im April erschienen:
    OpenLayers - Webentwicklung mit dynamischen Karten und Geodaten
    von M. Jansen und T. Adams, OpenSourcePress, München.
    ISBN: 978-3-937514-92-5
    URL:  http://openlayers-buch.de
   Dipl.-Geogr. Marc Jansen
   - Anwendungsentwickler -
   terrestris GmbH&  Co. KG
   Irmintrudisstraße 17
   53111 Bonn
   Tel:    ++49 (0)228 / 96 28 99 -53
   Fax:    ++49 (0)228 / 96 28 99 -57
   Email:  jansen at terrestris.de
   Web:    http://www.terrestris.de
   Amtsgericht Bonn, HRA 6835
   Komplementärin:  terrestris Verwaltungsgesellschaft mbH
   vertreten durch: Hinrich Paulsen, Till Adams
URL: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20100521/132618fe/attachment.html
More information about the Mapbender_dev mailing list
