[Mapbender_dev] EPSG:4326 tend to take random values even though maps are nearly the same
Abhishek Singh singhabhishek.bit at gmail.com
Fri May 21 09:55:01 EDT 2010
Hi Marc,
Please have a look at
http://www.mapbender.org/User_talk:Abhishek#Scale_calculation_for_non-metric_SRS.
I have written code that is compliant as per that documentation. As per as I
know if I modify getScale() in http/javascripts/mab_obj.js, then the values
in case of epsg:4326 and epsg:31467 should appear nearly equal. But they
they don't appear so. If you have some idea about why the problem
is occurring and how to remove that error, please feel free to share.
Thanks,
Abhishek Kumar Singh
BE/1349/2007
Information Technology
6th SEMESTER
BIT MESRA
On Fri, May 21, 2010 at 2:39 PM, Marc Jansen <jansen at terrestris.de> wrote:
>  Hi Abhishek,
> just a quick guessing here, but with a geographic projection like 4326
> scale isn't trivial to calculate, as there are AFAICT two scales to be
> considered (at the poles the metric distance between lon-values is zero).
> With Mercator-based projections both axises share the same scale.
> I am always more or less unsure about this stuff, so if the above contains
> errors, don't throw stones at me.
> Regards,
> Marc
> On 20.05.2010 10:33, Abhishek Singh wrote:
> Hi,
> I am having some problem with the scales values that appear in case of
> epsg:4326 and epsg:31467 in gui1. I have modified the getScale(), code
> snippet is available at http://osgeo.pastebin.com/U44pVU2v .The problem is
> that even though maps nearly appear to be the same for epsg:4326 and
> epsg:31467, the scale values aren't showing that correspondence. The scale
> values in case of epsg:4326 tend to take scale values like 1:14, 1:19 etc.
> please suggest how to remove that error.
> Thanks,
> BE/1349/2007
> 6th SEMESTER
> BIT MESRA
> Mapbender_dev mailing listMapbender_dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapbender_dev
>    Im April erschienen:
>    OpenLayers - Webentwicklung mit dynamischen Karten und Geodaten
>    von M. Jansen und T. Adams, OpenSourcePress, München.
>    ISBN: 978-3-937514-92-5
>    URL:  http://openlayers-buch.de
>   Dipl.-Geogr. Marc Jansen
>   - Anwendungsentwickler -
>   terrestris GmbH & Co. KG
>   Irmintrudisstraße 17
>   53111 Bonn
>   Tel:    ++49 (0)228 / 96 28 99 -53
>   Fax:    ++49 (0)228 / 96 28 99 -57
>   Email:  jansen at terrestris.de
>   Web:    http://www.terrestris.de
>   Amtsgericht Bonn, HRA 6835
>   Komplementärin:  terrestris Verwaltungsgesellschaft mbH
>   vertreten durch: Hinrich Paulsen, Till Adams
URL: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20100521/b2aac793/attachment.html
More information about the Mapbender_dev mailing list
