[Mapbender_dev] [Mapbender] #718: Non-transactional geometries
are not visible during digitizing
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Nov 12 03:20:19 EST 2010
Thomas Baschetti wrote:
> On 11.11.2010 17:01, Mapbender wrote:
>> #718: Non-transactional geometries are not visible during digitizing
>> They should be displayed, but be uneditable
> I disagree on this one, Non-transactional geometries should be
> unsaveable to the server,
> but editable in the client. I will present a use-case next week.
Thanks for your input.
Actually we supported both cases (always unsaveable, but both editable
and uneditable), unfortunately the uneditable case broke, because it's
rarely used. Typically, we use the uneditable case for snapping only.
The editable case is for manipulating and then inserting into an actual
WFS-T.
Curious about your use case.
Cheers,
Christoph
Where2B Konferenz 2010
09. Dezember 2010 in Bonn
www.where2b-conference.com
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
