[Mapbender_dev] [Mapbender] #718: Non-transactional geometries
are not visible during digitizing
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Nov 12 03:28:07 EST 2010
Christoph Baudson wrote:
> Thomas Baschetti wrote:
>> On 11.11.2010 17:01, Mapbender wrote:
>>> #718: Non-transactional geometries are not visible during digitizing
>>> They should be displayed, but be uneditable
>> I disagree on this one, Non-transactional geometries should be
>> unsaveable to the server,
>> but editable in the client. I will present a use-case next week.
> Thanks for your input.
> Actually we supported both cases (always unsaveable, but both editable
> and uneditable), unfortunately the uneditable case broke, because it's
> rarely used. Typically, we use the uneditable case for snapping only.
> The editable case is for manipulating and then inserting into an
> actual WFS-T.
This configuration is made in digitize_default.conf:
nonTransactionalEditable = true/false
I should create a wiki site that explains the configuration file.
Christoph
> Curious about your use case.
> Cheers,
> Christoph
Where2B Konferenz 2010
09. Dezember 2010 in Bonn
www.where2b-conference.com
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
