[Mapbender_dev] [Mapbender] #718: Non-transactional geometries
are not visible during digitizing
Thomas Baschetti
info at thomas-baschetti.de
Fri Nov 12 03:41:33 EST 2010
>> Thomas Baschetti wrote:
>>> On 11.11.2010 17:01, Mapbender wrote:
>>>> #718: Non-transactional geometries are not visible during digitizing
>>>> They should be displayed, but be uneditable
>>> I disagree on this one, Non-transactional geometries should be
>>> unsaveable to the server,
>>> but editable in the client. I will present a use-case next week.
>> Thanks for your input.
>> Actually we supported both cases (always unsaveable, but both
>> editable and uneditable), unfortunately the uneditable case broke,
>> because it's rarely used. Typically, we use the uneditable case for
>> snapping only. The editable case is for manipulating and then
>> inserting into an actual WFS-T.
> This configuration is made in digitize_default.conf:
> nonTransactionalEditable = true/false
This is what i use at the moment, but then geometries seem to be
deletable in the database (button is shown), which confuses some users.
> I should create a wiki site that explains the configuration file.
yes, please ;-)
> Christoph
>> Curious about your use case.
It's something like (i use german here)
- Gebiet über auswählen (z.B. Wahlbezirk, Kindergarteneinzugsgebiet,
mehrere Flurstück...)
- Editieren und/oder puffern der Geometrien
- mit dieser Geometrie Abfrage auf z.B. Einwohnerdaten, ALB-Daten usw.
Zweck:
- Ermitteln von Einwohner in Gebieten, wenn diese geändert werden sollen.
- Ermitteln von Einwohnern in Gefahrenzonen (X Meter um Bombenfund)
- Ermitteln von Grundstücksbesitzern
I will explain in Detail and perhaps create a demo-site next week.
Thomas
Thomas Baschetti - Systemanalyse Geographische Informationssysteme
Hakenstraße 8D
49074 Osnabrück
Tel: 0541 25 91 90 | mobil 01577 189 25 91
E-Mail: info at thomas-baschetti.de
www.thomas-baschetti.de
Ust-IdNr.: DE264355072
More information about the Mapbender_dev
