[Mapbender_dev] [Mapbender] #718: Non-transactional geometries are not visible during digitizing
Christoph Baudson christoph.baudson at wheregroup.com
Fri Nov 12 04:46:02 EST 2010
>>>>>  They should be displayed, but be uneditable
>>>> I disagree on this one, Non-transactional geometries should be
>>>> unsaveable to the server,
>>>> but editable in the client. I will present a use-case next week.
>>> Thanks for your input.
>>> Actually we supported both cases (always unsaveable, but both
>>> editable and uneditable), unfortunately the uneditable case broke,
>>> because it's rarely used. Typically, we use the uneditable case for
>>> snapping only. The editable case is for manipulating and then
>>> inserting into an actual WFS-T.
>> This configuration is made in digitize_default.conf:
>> nonTransactionalEditable = true/false
> This is what i use at the moment, but then geometries seem to be
> deletable in the database (button is shown), which confuses some users.
The workaround we use is to delete the transactional URL in the WFS table.
Then you need to update the WFS in Mapbender.
Let me know if this works.
Christoph
>> I should create a wiki site that explains the configuration file.
> yes, please ;-)
>> Christoph
>>> Curious about your use case.
> It's something like (i use german here)
> - Gebiet über auswählen (z.B. Wahlbezirk, Kindergarteneinzugsgebiet,
> mehrere Flurstück...)
> - Editieren und/oder puffern der Geometrien
> - mit dieser Geometrie Abfrage auf z.B. Einwohnerdaten, ALB-Daten usw.
> Zweck:
> - Ermitteln von Einwohner in Gebieten, wenn diese geändert werden sollen.
> - Ermitteln von Einwohnern in Gefahrenzonen (X Meter um Bombenfund)
> - Ermitteln von Grundstücksbesitzern
> I will explain in Detail and perhaps create a demo-site next week.
> Thomas
Where2B Konferenz 2010
09. Dezember 2010 in Bonn
www.where2b-conference.com
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
